Hi Everybody!
I recently released an updated version of MoKgVm2DVD (now called MKVtools) that now has the added capability of converting mkv videos into mp4 files. It's got a preset for converting files that are playable on iphones/ipods that I've been able to successfully test on my iphone and ipod.
I know that there is an interest out there for converting mkv videos into formats playable on the Apple TV, Xbox 360 and PS3. Unfortunately, I don't have any of those devices to test with. So I've got a beta of MKVtools at - http://emmgunn.com/betadownload.html - that has presets for all these devices that should theoretically work. I'm hoping that some of you might give it a try and provide some feedback either here or sent to emmgunnbeta@gmail.com. Thanks in advance for any help.
do you know if .mkv can be converted to QT w any of the freeware/shareware tools?
to an .avi or /mpg?
are all the tools that do this purchase ware?
I have onlu one to two files to convert for a newsgroup reader and it would not interest me for my own use.
cheersMPro 2.66 3GB RAM 1.5TB HD's
MigliaMiniHD
QTPro, MPEG2 add on MPlayerX2
MPEG Streamclip
24 + 21" samsung flat panels
G4dual 2GB
AlchemyDVR card -
MKVtools will change .mkv files to either .avi or .mp4, though there are some limitations to the codecs it can handle. For example, it can't handle DTS audio. You don't have to buy it to convert .mkv files. It'll function unregistered. The two things that the registration will do is (1) get rid of a nag screen that pops up when you start a job, and (2) for "power users" it'll let you build up a queue of jobs so that you can, for example, process a number of files overnight, which it sounds like you don't need.
BTW, registration also encourages further development of the software. I know that sounds cliche and you've heard that form every shareware developer, but no one has shared with you the details of this encouragement. Here is how it works. Registration is $3.50. So for every two people that register, I can buy a 6-pack of Anchor Steam beer, and as everybody knows, it's impossible to get any decent programming done without and icy cold beer within easy reach.
MkvТоMp4 v0.224 - rapid tool for repack Mkv to Mp4
By oreons in forum Video ConversionReplies: 808Last Post: 7th Mar 2022, 01:43 -
MKV Compression to a smaller MKV or MP4
By THRobinson in forum Video ConversionReplies: 9Last Post: 20th Jul 2018, 10:56 -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
muxing .264 stream to .mkv, or to .mp4 first, an then to .mkv ?
By codemaster in forum Video ConversionReplies: 2Last Post: 20th Sep 2011, 20:50 -
Issues Converting MKV to MP4 (could be due to damaged MKV header??)
By MohQ in forum Video ConversionReplies: 1Last Post: 1st Feb 2008, 03:10
