Thank you in advance for any assistance I may receive. I only have cursory knowledge of video/audio and my own research has not resulted in any solutions. Here is the problem.
I have a video file that I downloaded where the video plays fine but the audio does not play. I did not create or convert the file, hence I do not have any source information. The file is an AVI and the video codec is DX50/divx. I used the application "G-Spot", and it stated the video is using the audio codec "0x0055 MPEG-1 Layer 3" and it also stated that the codec is installed on my system. I have attempted to play the file in RealPlayer, WMP, and VLC with the same result, no audio. Other files on my system that use MP3 audio play without any issues. I have uninstalled, reinstalled codecs to no avail.
Upon attempting to render the audio in G-Spot, the information provided under "Proposed Codec Solutions and Tests" states:
Failed to connect Output pin 0x06db6df4 ("Audio 1") on Avi Splitter to input pin 0x06c3dc ("In") on filter 0x01f23267 ("ffdshow Audio Decoder"). ConnectDirect() failed. Error: 0x80040207: There is no common media type between these pins.
Here are some further details, there is not a low hum, hiss, muffle, or anything of that nature. I mention this because I did some reading about the application Sound Forge and came away with the impression that it would be able to fix issues such as that but not an issue where the audio track is completely not audible. Is there a tool, application that I can use to restore the audio of this file? Thank you.
Other G-Spot information:
Container
File Length Correct
Divx Style "packed bitstream" AVI
AVI v1.0
Interleave: 1 vid frame (33ms), preload=522
Audio frames: Split across interleaves
Video: 43.1 MB (87.55%)
Audio: 5.62 MB (11.41%)
AVI Overhead: 526 KB (1.04%)
User Data/Metadata
[JUNK] VirtualDub build 18160/release
[USER] DivX503b1594p
avs (avi to avi) ends up out of sync ... winavi output file too big
By mandy in forum Video ConversionReplies: 1Last Post: 21st Aug 2009, 05:56 -
No audio in preview or output MPG file in VOB2MPG 2.0
By scruzphreak in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 16th Jul 2009, 12:20 -
No Audio output installed
By ray316 in forum ComputerReplies: 1Last Post: 12th Mar 2009, 16:53 -
Audio doesn't play in AVI files, although AC3 codec IS installed
By DVantrease in forum Software PlayingReplies: 2Last Post: 16th Jan 2009, 17:57 -
VD Complain Audio Codec Not Installed
By ks47 in forum Newbie / General discussionsReplies: 2Last Post: 19th Oct 2007, 10:46
