My wife & I just used TMPGEnc DVD Author 3 to make a 40 minute slideshow with 12 chapters. It was to be played at a family gathering, so I configured it to play continuously on a loop. Now that the gathering is done, several people want copies of the DVD to keep. I'd like to reconfigure this DVD now, so that it will not play on a loop ... and will just return to the menu when done. No other changes. I know where this setting is, but do I have to start all over & re-author this DVD from the beginning just to change this 1 setting? Or can I just make a simple change with my existing DVD file? Even if I do have to start all over, would I be able to "copy & paste" any part of my previous DVD file to save some time? I haven't been able to figure this out. Thank you!
I assume that you didn't save project file neither source photos. Right? So, the quickest way would be to copy DVD to HD and edit it (ifo/bup files) in PgcEdit to change the loop option to 'return to a menu'. Otherwise you would need to import the DVD to TDA via Source Wizard, and re-create menus - they cannot be imported as they are rendered as a video, and chapter links are no longer editable.
Thank you!
Actually, the project file is saved & the photos are still in exactly the same place. I've tried simply changing the loop setting in the project file, but I get a message that pops up about having to redo everything. Don't know the exact message, because I'm at work now. Either way though, I tried what I thought might work, but it didn't. Should there be a quick solution? Thank you again! -
OK, so you need to go to "Menu" tab, and click on button "Global DVD menu setting" > General > Track playback end action setting > and select preferred option. Done
I'll give that a try right when I get home ... thank you very much!
Edit: And it worked perfectly ... thank you!
TMPGEnc DVD Author question/
By ingeborgdot in forum Authoring (DVD)Replies: 11Last Post: 22nd Sep 2008, 13:58 -
New TMPGEnc DVD Author Question
By Robert Simandl in forum Authoring (DVD)Replies: 1Last Post: 11th Jun 2008, 07:47 -
TMPGEnc DVD Author - Quick Slideshow Question
By heyjjjaded in forum Authoring (DVD)Replies: 2Last Post: 4th Mar 2008, 06:13 -
TMPGEnc DVD Author 3 Question ...
By ZaYoOoD in forum Authoring (DVD)Replies: 5Last Post: 3rd Dec 2007, 07:17 -
By newtie in forum Authoring (DVD)Replies: 1Last Post: 4th Sep 2007, 09:49
