Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
Results 1 to 12 of 12
    May 2008
    India
    hi,
    i have sony vegas 8 pro.
    how should i make 5.1 surround sound movie from ordinary video file with extensions(.dat ,.avi,.mpg,.....etc.) with help of sony vegas pro 8? and how it would burn on dvd?
    is there any other softwares to make it possible?
    Oct 2005
    666th portal
    to make 5.1 surround you need to have 6 separate wav files or a 6 channel wav/aiff to start with. use ac-3 2ch. for stereo sources.
    May 2008
    India
    thanks,
    but you mentioned WAV file which is audio file
    i mean to say mixing for ordinary video files.
    any help for video file conversion to 5.1 surround mixing on vegas?
    Apr 2004
    Miskatonic U
    Don't bother. If you don't understand that a video file with sound means it has an audio component, then trying to mix 5.1 is going to be beyond your skills.
    Instead, use DVD Flick to encode your video files and tick the Upmix function under preferences.
    Read my blog here.
    May 2008
    India
    i am newbie in video editing.
    how can i separate 6 channel wav from stereo source? will sony vegas help me for this? if yes then how?
  6. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    The guide I posted (above) shows you how to create the 6 wav files that you need, using a stereo source.
    Honestly, unless you really have a need, it isn't worth doing.
    You might look at DAudioK, which can create a 5.1 AC3 track from a stereo track using a similar method to DVD Flick.
    Vegas is designed to properly mix 5.1 audio track from separate audio elements, not stereo MP3 tracks. Also, using compressed audio like MP3 as source is less than ideal, as the compression levels used for most AVI files muddies what stereo separate there was to begin with.
    Read my blog here.
  7. Member Cunhambebe's Avatar
    Mar 2004
    São Paulo - Brazil
    Will you please tell me where the VST folder is? Pressing Ctrl + Alt + 1 , shows the folders but I still can't find them using Windows Explorer. Does anyone know why? Thanks a lot.
  8. WOMBLE mpeg Video Wizard DVD can take an MPEG with stereo audio and save it in mpeg with 5.1AC3 Audio
    May 2008
    India
    thanks
    May 2008
    India
    hi
    i use your guide to make 5.1 mixing
    however, in sony vegas mixing part,
    after all editing at rendering choosing dolby digital .ac3 file type
    it does not show template for this. at template space it show no existing template for this type
    and if press save it show format not supported of given media
    i have sony vegas pro 8
    what should i do next?
    did my .ac3 plugin missed?
    if yes where should i get it?
  11. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    AC3 is not standard in Vegas unless you buy the plugin or have DVD Architect installed.
    Read my blog here.
