OK, I'm a semi-n00b at this stuff, so it's quite possible that I'm being really stupid about something incredibly basic here -- but I'm having aspect ratio problems with MeGUI and I hope someone can help me figure this out...
All I want to do is to rip all my (legitimately purchased) DVD main movies to high-quality MP4 files suitable for viewing on my PC and for streaming to my PS3. Ideally, I would like to preserve the DVD's chapter info, and possibly also retain a subtitle stream. MeGUI seems like the tool of choice, so that's what I have been trying. I found a really excellent MeGUI tutorial here (https://forum.videohelp.com/topic333634.html), and everything seemed pretty straightforward.
When I'm building the .avs script in MeGUI, the "original video" is noticably vertically "stretched". I figure this is normal, since the DVD video is encoded as 720x480 with a 9x6 aspect ratio, but MeGUI is displaying it as 1:1.
If I just allow MeGUI to auto-crop and then resize to suggested dimensions, everything works fine. For the movie "Legally Blonde" I end up with final, cropped movie file with dimensions 720x304 -- pretty close to 2.35:1.
Everything I have read suggests that it would be much better to encode in an anamorphic format, in order to get the best resolution. So I enable "clever anamorphic" and select "overcrop to achieve mod16". The resulting .avs cript looks like it is coded for a 2.35:1 display AR (darX=11887, darY=5000) -- which I *think* is correct, but even if I change it to something like 720x304, or 16x9, nothing seems to change.
No matter what I do, the "preview AVS" video is strethced vertically, as is the final produced .mp4 file.
Am I doing something wrong? Has anyone written a step-by-step for converting anamorphic DVDs with MeGUI using the "clever anamorphic" mode and getting the video to have the correct AR?
Thanks in advance for any help!
Results 1 to 1 of 1
MeGui: error in encoding: "x264.exe:unrecognized option --progress"
By Julllie in forum Video ConversionReplies: 4Last Post: 30th Apr 2011, 05:21 -
Visual Hub / DVD / Where is "force anamorphic" ?
By webstar in forum MacReplies: 2Last Post: 30th Jun 2010, 04:13 -
how can i select "parts" of a movie to encode only using megui
By llmercll in forum Video ConversionReplies: 4Last Post: 7th Feb 2009, 02:07 -
DVD with menus, replacing "bad" video with "good" video
By chipsndukes in forum Authoring (DVD)Replies: 34Last Post: 4th Dec 2008, 17:45 -
MeGUI - Clever Anamorphic Encoding?
By bullet_ballet in forum Newbie / General discussionsReplies: 1Last Post: 2nd Sep 2007, 23:29
