  1. Member Cunhambebe's Avatar
    Mar 2004
    São Paulo - Brazil
    Hi there! I'm starting to encode using MEGUI and X264. That's absolutely perfect!
    Now I'm trying to find another GUI for x264, since I'd like to try it using VirtualDubMod, if it's ever possible.
    I was reading a tutorial on X264 encoding options here:
    http://www.digital-digest.com/articles/x264_options_page3.html
    ...but I was not sure if that GUI belongs to StaxRip or whatever. Can any of you help me, please? It's just an answer. No DARs or PARs, I promise
    Cheers
    Mark
    It's staxrip.
  3. Member Cunhambebe's Avatar
    Mar 2004
    São Paulo - Brazil
    Thanks, Baldrick. Glad to "see ya" again.
    Cheers,
    Mark
  4. Mod Neophyte redwudz's Avatar
    USA
    FairUse Wizard also uses VD Mod and a VFW version of H.264. Set to use all cores, it works well for me.
  5. Banned
    Jun 2007
    UNREACHABLE
    Forget VirtualDubMod and start using LeiMing's x264 GUI:
    http://forum.doom9.org/showthread.php?t=112770
    And keep having fun!
  6. Member Cunhambebe's Avatar
    Mar 2004
    São Paulo - Brazil
    Thanks so much, redwudz. You're always very gentle.
    Ah obrigado Midzuki It looks neat. Do you use it? Thanks for the input.
    Cheers,
    Mark
    Edit:
    Meanwhile at Doom9's:
    JoeBG: Does it have commandline functions?
    Sharktooth: it's quite silly to ask for command line functions in a gui for a command line encoder... dont you think?
    lololol
