G'day
I hope I'm in the right forum to ask this, if not please be kind to me. I'm an old bugger.
Is there any software to remove water marks from images: jpg, bmp?
Thanks for any help
John
It depends on how they were put there. Most times they are part of the image with a JPEG, so not likely to remove them. Some companies put their name over images of their products and that's about impossible to remove. If it's just a small logo, maybe, but you would have to redraw that part of the image, which could take a lot of work and time. For freeware, try Gimp: http://www.gimp.org/
Payware, Photoshop. ($$$$) -
Yes. I thought it couldn't be done.
Thanks mate. I'll try Gimp.
John -
You could try Virtualdub and the DeLogo filter. It's often discussed on these forums for removing logos from videos, but I don't see any reason it wouldn't work with a bmp or jpg as VirtualDub is capable of opening both. The hard part is that you can't append a "white" frame to a single image for sampling. But if you're familiar with AviSynth it's an easy script to open the image and a white frame for sampling to build the filter files.
Edit: Actually, now that I think about it, the hard part would be getting the watermark against a black background, since you only have the one image. I think I'd still try it though."Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books
mark 9-20-10 on your calenders...
By deadrats in forum Video ConversionReplies: 2Last Post: 18th Sep 2010, 01:46 -
JPG to AVI Back to JPG is it possible?
By concisa in forum Video ConversionReplies: 3Last Post: 11th Apr 2009, 09:06 -
Water for Gas?
By MeDiCo_BrUjO in forum Off topicReplies: 2Last Post: 17th Jul 2008, 16:10 -
Remove Water Spots from video
By Richkut in forum RestorationReplies: 2Last Post: 8th Jan 2008, 22:56 -
Players w/ mark-in, mark-out
By kippard in forum Software PlayingReplies: 0Last Post: 30th Dec 2007, 20:16
