I really, really, really could not recommend AMD to anyone at this time, and I am a long-time user of their products. It may well be a dead-end platform. But there are some values there.
Future upgradeability is to me a major concern, re-sellability can be an issue. Four RAM slots instead of two may not be needed now, but in a year or two?
Same with the RAM speed, if the board and chip support it, the $68.00 may be well spent. In maybe six months, if you can sell the old RAM for close to what you paid, then buy the faster RAM at a lower price, this might be a way to go.
Some things can be upgraded cheap, some not. Extra RAM on a four-slot board, no problem. 800 MHZ RAM to 1066 involves Removing the old RAM and chucking it out the window.
That 2600 card is good for HDMI-out, but as a gaming card, it ain't great, I have one. You could Crossfire it for some improvement, but for gaming, Nvidia rules. Two of their older cards, one in a slower PC, both beat the ATI card to death. That 8800GT you are looking at is lightyears ahead. DVI to HDMI works just as well for TV-out.
Strongly recommend stick with stock hsf unless overclocking. That's a lot of waranty to void on an expensive part.
Results 31 to 32 of 32
A lot of these new technologies don't get us a lot more real performance.
Like dual channel memeory, that it hardly give us any edge, I was suprised when I put together the first MB with it, then I find out TOM_Hardware also saw the same outcome.
Even dual core pentium does not do anything near twice off pentium-4. They just run cooler and quieter.
Pentium is better than the cheap Celeron mostly due to the bigger cache. So it only has advantage on large and high end applications.
I used Pc-wizard and Sandra to bench mark upgrade, and see less and less improvment with new MB, CPU, GPU, hard drive, memory... Are the PC technologies stalled ?
How to copy dvd movies to computer and build a liabrary on the computer
By robrpb in forum Newbie / General discussionsReplies: 3Last Post: 4th Jun 2010, 19:16 -
computer build
By tofuguy in forum ComputerReplies: 31Last Post: 11th Dec 2009, 11:12 -
Guide: How to Build a Basic Computer
By redwudz in forum ComputerReplies: 24Last Post: 10th Apr 2009, 21:28 -
Don't buy...build your next computer!
By rcguy1 in forum Newbie / General discussionsReplies: 38Last Post: 17th Sep 2008, 12:12 -
Computer build up
By lsvtec in forum ComputerReplies: 14Last Post: 6th May 2008, 08:26
