If so, I think I have a bad one because sometimes when I have a firewire HD connected to it, and then I go to turn on my camera, the HD loses its connection as if one firewire device interferes with another one plugged into the same card.
Can someone recommend a good firewire card that I can buy, preferably more than 3 ports on it?
This is a common problem when using a firewire HDD and camcorder on the same card. Better to use separate cards. Adding inputs won't help, you need additional controller chips to the PCI bus.Originally Posted by sdsumike619Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
So the problem isn't the card, it's that I need another card in other words?
That is one possible solution. Motherboard 1394 ports behave better in my experience. Others may have better comments and product recommendations.Originally Posted by sdsumike619Recommends: Kiva.org - Loans that change lives.
Is there any PCI decoder cards out there that can do this?
By GLE3 in forum Newbie / General discussionsReplies: 11Last Post: 25th Apr 2009, 15:30 -
Have they created an external enclosure for pci cards?
By yoda313 in forum ComputerReplies: 13Last Post: 21st Aug 2008, 22:58 -
Good Firewire PCI card for Capturing HDTV?
By superdud1400 in forum Capturing and VCRReplies: 1Last Post: 12th Jun 2008, 05:11 -
I need a good FireWire PCI card for capturing video.
By mob in forum Capturing and VCRReplies: 11Last Post: 1st Apr 2008, 01:19 -
eSATA PCI cards
By piano632 in forum ComputerReplies: 4Last Post: 7th Jan 2008, 14:55
