Hello, im having problems burning on RW media (with my Samsung SH-S202J), it affects both cd/dvd. Im running windows xp, and all the latest drivers etc.
The burn goes fine as far as you can monitor it, ive been useing latest nero/nero7/imgburner and cdxp, tryied burning from opticalsource and from local harddrive. The problem im having is that on all other players/drivers i cant find the media i burned (claims the media is empty), on any other drive then the one i burnt it on.
Ive tryied 6 diffent DVD+r RW media verbatim infiniti Fujifilm memorex maxwell and datawrite. So im guessing the media aint the problem. And i since it affects CD+R RWs also im guessing the problem isnt the media.
The driver works fine on DVD+/-R and CD+R no mather what manufacture i use.
What could be wrong with my burner?
This message is posted on Videohelp.com and sent to Samsung.com
Best Regards
Are you fully formatting the RW discs before you burn them? If you aren't that could be the problem.
Yes i am fully erasing them also ofcourse tryied fast erasying them also. The thing that irritate me the most is i cant test it the drive on another computer since i dont have accses to another computer since i just moved 40miles.
And what ever i burn works on my sh202j/stationary but not on my laptop/dvdplayer. But if i burn with my laptop it works on all the others problem is that, the laptop only got 10/10 network card and it takes for ever to transfer a bigfiles.
So i rather burn on my stationary, and if you bought something you want it to work. -
How exactly are you burning the discs? (ie: what mode are you using) You should just be burning the discs as data (the same as you would a regular DVD). Also, don't use multi-session.
Google is your Friend
New to double sided dvd's - Burning Hi Quality Media Files
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 7Last Post: 27th Apr 2012, 21:50 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Problem playing wmv files in Windows Media Player and Media Player Classic.
By rayden54 in forum Software PlayingReplies: 4Last Post: 1st Aug 2008, 23:49 -
What is your favorite burning media for video?
By yoda313 in forum PollsReplies: 29Last Post: 12th Apr 2008, 17:59 -
*SOLVED* Media problem or workflow problem? (Media problem)
By nosleep in forum Authoring (DVD)Replies: 7Last Post: 2nd Jan 2008, 21:35
