    Mar 2005
    After I use Auto Gordon Knot to convert an mpg file to Xvid, the program shuts down instead of staying open (the box is checked to do nothing, not shut down). Worse, when I try to launch the program again, it won't open unless I reboot my computer. What is going on? How can I fix this?
  2. Hi-
    Now, that could be a problem, but I suspect it's still there and open. Have you checked in the System Tray (in the lower right) for the icon so you can restore it? And if worse comes to worst, a CTRL-ALT-Delete should allow you to find the AutoGK.exe and close it so you can open it again without rebooting.
    However, I just did a quick test encode and it stayed right there when done. You might try deleting AutoGK and reinstalling it.
