Hi, I got an Mkv file with dual audio (Japanese & english). I want to burn it with the english audio.I tried using AviMux GUI and it says everything is successful but when I try to play the mkv the subs show but even though the audio is ticked on I hear no sound. I also tried using convertxtodvd and winavi to just convert both audio files but I always get errors. When I play it with my MPC player everythig works fine. But iwant to convert and burn it. Any help would be greatly appreciated.
What are the errors in latest ConvertXtoDVD and WinAVI?
You could also try FAVC or DVD Flick - either is far preferable to WinAVI.
I have had mkv files that all three programs choked on. I never found the reason for it, nor cared to look. The solution that has always worked for me is to use MKVExtractGUI (and mkvtoolnix, of course) to extract the elements I wanted (video/audio/subs), then to use mkvMergeGUI to create a new mkv file with just these elements. It only takes a few minutes, and on every occasion the resulting files has then converted correctly, without errors or sync issues.
It might be worth a try in your caseRead my blog here.
here is part of convertxtodvd log file.Originally Posted by Baldrick
5/3/2008 8:26:45 AM warning ENG:[h264 @ 66B0A000]no frame!
5/3/2008 8:26:45 AM warning ENG:[h264 @ 66B0A000]AVC: nal size 1226864481
5/3/2008 8:26:45 AM warning ENG:[h264 @ 66B0A000]AVC: nal size 858860588
5/3/2008 8:26:45 AM warning ENG:[h264 @ 66B0A000]AVC: nal size 858795052
5/3/2008 8:26:43 AM warning ENG:[h264 @ 66B0A000]AVC: nal size 842345516
5/3/2008 8:26:43 AM warning ENG:[h264 @ 66B0A000]no frame!
5/3/2008 8:26:43 AM warning ENG:[h264 @ 66B0A000]AVC: nal size 1214609708
5/3/2008 8:26:42 AM warning ENG:[h264 @ 66B0A000]no frame!
5/3/2008 8:26:42 AM warning ENG:[h264 @ 66B0A000]AVC: nal size 842411052
5/3/2008 8:26:42 AM warning ENG:[h264 @ 66B0A000]AVC: nal size 842476588
5/3/2008 8:26:42 AM warning ENG:[h264 @ 66B0A000]AVC: nal size 1097098272
5/3/2008 8:26:41 AM warning ENG:[h264 @ 66B0A000]no frame!
5/3/2008 8:26:41 AM warning ENG:[h264 @ 66B0A000]AVC: nal size 1147762281
5/3/2008 8:26:41 AM warning ENG:[h264 @ 66B0A000]AVC: nal size 842607660
5/3/2008 8:26:41 AM warning ENG:[h264 @ 66B0A000]AVC: nal size 842542124
5/3/2008 8:26:40 AM warning Error while decoding stream #0.0
5/3/2008 8:26:37 AM warning Error while decoding stream #0.0
5/3/2008 8:26:36 AM warning ENG:[h264 @ 66B0A000]AVC: nal size 842279980
5/3/2008 8:26:36 AM warning ENG:[h264 @ 66B0A000]no frame!
5/3/2008 8:26:36 AM warning ENG:[h264 @ 66B0A000]AVC: nal size 1226864481
5/3/2008 8:26:35 AM warning Error while decoding stream #0.0
5/3/2008 8:26:35 AM warning ENG:[h264 @ 66B0A000]no frame!
5/3/2008 8:26:35 AM warning ENG:[h264 @ 66B0A000]AVC: nal size 842214444
5/3/2008 8:26:34 AM warning ENG:[h264 @ 66B0A000]AVC: nal size 842148908
5/3/2008 8:26:32 AM warning ENG:[h264 @ 66B0A000]no frame!
5/3/2008 8:26:32 AM warning ENG:[h264 @ 66B0A000]AVC: nal size 1214609708
5/3/2008 8:26:32 AM warning ENG:[h264 @ 66B0A000]AVC: nal size 842083372
5/3/2008 8:26:32 AM warning Error while decoding stream #0.0
5/3/2008 8:26:30 AM warning Error while decoding stream #0.0
5/3/2008 8:26:29 AM warning ENG:[h264 @ 66B0A000]AVC: nal size 842017836
5/3/2008 8:26:29 AM warning ENG:[h264 @ 66B0A000]no frame!
5/3/2008 8:26:29 AM warning ENG:[h264 @ 66B0A000]AVC: nal size 1466460532
5/3/2008 8:26:27 AM warning Error while decoding stream #0.0
5/3/2008 8:26:26 AM warning ENG:[h264 @ 66B0A000]no frame!
5/3/2008 8:26:26 AM warning ENG:[h264 @ 66B0A000]AVC: nal size 825830444
5/3/2008 8:26:26 AM warning ENG:[h264 @ 66B0A000]AVC: nal size 825764908
5/3/2008 8:26:26 AM warning Error while decoding stream #0.0
5/3/2008 8:26:25 AM warning ENG:[h264 @ 66B0A000]AVC: nal size 1214609708
5/3/2008 8:26:25 AM warning ENG:[h264 @ 66B0A000]no frame!
5/3/2008 8:26:25 AM warning ENG:[h264 @ 66B0A000]AVC: nal size 825699372
5/3/2008 8:26:25 AM warning ENG:[h264 @ 66B0A000]AVC: nal size 825633836
5/3/2008 8:26:24 AM warning ENG:[h264 @ 66B0A000]no frame!
5/3/2008 8:26:24 AM warning ENG:[h264 @ 66B0A000]AVC: nal size 1226861173
5/3/2008 8:26:23 AM warning ENG:[h264 @ 66B0A000]no frame!
5/3/2008 8:26:23 AM warning ENG:[h264 @ 66B0A000]AVC: nal size 825568300
5/3/2008 8:26:23 AM warning ENG:[h264 @ 66B0A000]AVC: nal size 825502764
5/3/2008 8:26:23 AM warning Error while decoding stream #0.0
5/3/2008 8:26:21 AM warning ENG:[h264 @ 66B0A000]no frame!
5/3/2008 8:26:21 AM warning ENG:[h264 @ 66B0A000]AVC: nal size 1315908640
5/3/2008 8:26:21 AM warning ENG:[h264 @ 66B0A000]AVC: nal size 825437228
5/3/2008 8:26:19 AM warning ENG:[h264 @ 66B0A000]no frame!
5/3/2008 8:26:19 AM warning ENG:[h264 @ 66B0A000]AVC: nal size 1466528872
5/3/2008 8:26:19 AM warning ENG:[h264 @ 66B0A000]AVC: nal size 825371692
5/3/2008 8:26:19 AM warning ENG:[h264 @ 66B0A000]AVC: nal size 825306156
5/3/2008 8:26:19 AM warning Error while decoding stream #0.0
5/3/2008 8:26:18 AM warning ENG:[h264 @ 66B0A000]AVC: nal size 1197569128
5/3/2008 8:26:17 AM warning ENG:[h264 @ 66B0A000]no frame!
5/3/2008 8:26:17 AM warning ENG:[h264 @ 66B0A000]AVC: nal size 1315908640
5/3/2008 8:26:17 AM warning ENG:[h264 @ 66B0A000]AVC: nal size 825240620
5/3/2008 8:26:16 AM warning ENG:[h264 @ 66B0A000]no frame!
5/3/2008 8:26:16 AM warning ENG:[h264 @ 66B0A000]AVC: nal size 1416126836
5/3/2008 8:26:16 AM warning Error while decoding stream #0.0
5/3/2008 8:26:16 AM warning ENG:[h264 @ 66B0A000]AVC: nal size 959196231
5/3/2008 8:26:16 AM warning ENG:[h264 @ 66B0A000]AVC: nal size 942419015
5/3/2008 8:26:15 AM warning ENG:[h264 @ 66B0A000]no frame!
5/3/2008 8:26:15 AM warning ENG:[h264 @ 66B0A000]AVC: nal size 1416127776
5/3/2008 8:26:15 AM warning ENG:[h264 @ 66B0A000]AVC: nal size 925641799
5/3/2008 8:26:15 AM warning ENG:[h264 @ 66B0A000]AVC: nal size 908864583
5/3/2008 8:26:14 AM warning Error while decoding stream #0.0
5/3/2008 8:26:13 AM warning ENG:[h264 @ 66B0A000]no frame!
5/3/2008 8:26:12 AM warning Error while decoding stream #0.0
5/3/2008 8:26:11 AM warning ENG:[h264 @ 66B0A000]no frame!
5/3/2008 8:26:11 AM warning ENG:[h264 @ 66B0A000]AVC: nal size 892087367
5/3/2008 8:26:11 AM warning ENG:[h264 @ 66B0A000]AVC: nal size 875310151
5/3/2008 8:26:11 AM warning ENG:[h264 @ 66B0A000]AVC: nal size 1466247012
5/3/2008 8:26:11 AM warning ENG:[h264 @ 66B0A000]AVC: nal size 858532935
5/3/2008 8:26:11 AM warning ENG:[h264 @ 66B0A000]AVC: nal size 841755719
5/3/2008 8:26:10 AM warning Error while decoding stream #0.0
5/3/2008 8:26:09 AM warning ENG:[h264 @ 66B0A000]no frame!
5/3/2008 8:26:09 AM warning ENG:[h264 @ 66B0A000]AVC: nal size 1113941615
5/3/2008 8:26:09 AM warning ENG:[h264 @ 66B0A000]AVC: nal size 824978503
5/3/2008 8:26:09 AM warning ENG:[h264 @ 66B0A000]AVC: nal size 808201287
5/3/2008 8:26:08 AM warning Error while decoding stream #0.0
5/3/2008 8:26:06 AM warning Error while decoding stream #0.0
5/3/2008 8:26:04 AM warning Error while decoding stream #0.0
5/3/2008 8:25:45 AM info Stream #1 Sync. delay : 0.00 ms
5/3/2008 8:25:45 AM info Stream #0 Sync. delay : 0.00 ms
5/3/2008 8:25:45 AM info Output Stream#1 - Audio: ac3, 48000 Hz, mono, 192 kb/s, no automatic gain control
5/3/2008 8:25:45 AM info Output Stream#0 - Video: mpeg2video, yuv420p, 720x480, q=3-31, 8808 kb/s
5/3/2008 8:25:45 AM info Video Stream #0 Pulldown : 24.000 -> 29.97 Fps
5/3/2008 8:25:45 AM info Image processing: Fast bilinear resampler (640*480)->(544*480)
5/3/2008 8:25:45 AM info Image processing: Pad (Left:88 - Top:0 - Right:88 - Bottom:0)
5/3/2008 8:25:45 AM info Image processing: Deinterleave (640*480)
5/3/2008 8:25:45 AM info Video source original frame rate: 24.39
5/3/2008 8:25:45 AM info Output resolution: FULL D1 [720*480]
5/3/2008 8:25:45 AM info NTSC 29.97 FPS output format set by user
5/3/2008 8:25:45 AM info Widescreen (16:9) set by user
5/3/2008 8:25:45 AM info Video bitrate 0/8808/8808 Kbps (min/avg/max)
5/3/2008 8:25:45 AM info Converting "C:\gravitation"
5/3/2008 8:25:45 AM info ----------------Title #1----------------
5/3/2008 8:25:45 AM info Video bitrate has been set to maximum possible value for DVD specifications. Target size may not be reached.
5/3/2008 8:25:45 AM info Project size 4.2 Gb. (30.9 Mb. audio - 4.16 Gb. video)
5/3/2008 8:25:45 AM info Stream #1 - Audio: mpeg4aac, 44100 Hz, mono
5/3/2008 8:25:45 AM info Stream #0 - Video: h264, yuv420p, 640x480
5/3/2008 8:25:45 AM info 2 Stream(s) found - est. duration 00:22:07.437
5/3/2008 8:25:45 AM info Opening file "C:\gravitation"
5/3/2008 8:25:45 AM info [ ] Don't fix audio gaps
5/3/2008 8:25:45 AM info [X] Engine Log
5/3/2008 8:25:45 AM info Encoder quality: 33%
5/3/2008 8:25:45 AM info --------------Encoding begin--------------
5/3/2008 8:25:45 AM info --------------Menu settings end--------------
5/3/2008 8:25:45 AM info [ ] Sequential playback
5/3/2008 8:25:45 AM info [ ] Loop playback
5/3/2008 8:25:45 AM info [ ] Auto start playback
5/3/2008 8:25:45 AM info [X] Menu
5/3/2008 8:25:45 AM info --------------Menu settings begin--------------
5/3/2008 8:25:45 AM info --------------Default burn settings end--------------
5/3/2008 8:25:45 AM info Default speed selected: 4x
5/3/2008 8:25:45 AM info Compatible media types : CD-R, CD-RW, DL DVD+R
5/3/2008 8:25:45 AM info New Drive selected : 2:1:0 - TSSTcorp CDW/DVD TS-H492A HP03 [I] (Ide)
5/3/2008 8:25:45 AM info [ ] Delete files after burn complete
5/3/2008 8:25:45 AM info [ ] Don't eject after burn complete
5/3/2008 8:25:45 AM info [ ] Prefer SAO for DVD-R
5/3/2008 8:25:45 AM info [ ] Include originals
5/3/2008 8:25:45 AM info [ ] Burn result to DVD
5/3/2008 8:25:45 AM info --------------Default burn settings begin--------------
5/3/2008 8:24:56 AM info User default language : 1033 (0x0409h) - English (United States)
5/3/2008 8:24:56 AM info System default language : 1033 (0x0409h) - English (United States)
5/3/2008 8:24:56 AM info Version 2.2.3.258
5/3/2008 8:24:56 AM info ExeName : "C:\ConvertXtoDVD\ConvertXtoDvd.exe"
5/3/2008 8:24:56 AM info OS : Microsoft Windows XP Professional Service Pack 2 (Build 2600)
5/3/2008 8:24:55 AM info ******************** Report session started ********************
5/3/2008 8:24:55 AM info ******************** Report session started **** -
I find it odd that I only have problems with dual audio files and I tried changing the audio to just japanese with mkvtoolnix and though it did its job the problem persists when i try to convert it with convertxtodvd. I have several mkv files and have the same problem for all. when I use rmvb, avi,etc all seems fine.
I just upgraded from convertxtodvd 2 to version 3 and it looks like this version will burnmkv files but it keeps freezing? Please help. When I am converting with this program I can't multi task at all or it will screw up but even when I don't use the pc while it's converting it freezes.
Maybe try setting the priority lower to prevent freezing (in task manager)
If that doesn't work, you can try frameserving into convertx by using an avisynth script. If you are able to play the .mkv back normally on your pc, this should work. (of course use it on the .mkv with 1 audio from mkvmergegui)
DirectShowSource("PATH\FILE.mkv",fps=X,convertfps= true), where X is the true fps
Look up guides on avisynth.
Cheers
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 04:12 -
problem converting dual audio mkv
By projecttemp in forum Video ConversionReplies: 10Last Post: 18th Mar 2008, 16:53 -
Ripping DVD to MKV Dual audio and subs
By whizzykid in forum DVD RippingReplies: 2Last Post: 28th Feb 2008, 18:08 -
Dual Audio .ogm/.mkv to dvd
By aszwet1 in forum Newbie / General discussionsReplies: 1Last Post: 10th Jul 2007, 19:35 -
Dual audio .mkv/.ogm to DVD
By aszwet1 in forum Authoring (DVD)Replies: 1Last Post: 10th Jul 2007, 18:12
