I've been trying a couple - Any Video Encoder and EasyFLV. AVC gives a lot of control over audio - various variable bitrate profiles, has batch encoding which is nice but it's buggy and undependable, change some parameter - audio or video bitrate, frame rate, image dimension you may get no image.
EasyFLV works more consistently but doesn't do batch encoding and generally gives you less control over the audio.
Both of them have preset video bitrates that don't allow precise control if you're trying to use the "add black" trick to nudge up against the 350kbps tripwire to avoid YouTube re-encoding.
Is there an app that's non-buggy and gives more precise control? Free is of course good.
Thanks for all input.
you can use Avanti to convert to flv, you can control the values o f video/audio and add black bars
https://forum.videohelp.com/topic343287.html?highlight=avanti
or you can use the mencoder script provided by 45tripp in the youtube thread, it will automatically add the black bars( its what i use).I love it when a plan comes together! -
Originally Posted by ricardouk
Thanks, I'll definitely check it out. By "add black" I'm referring to the trick of appending a low bitrate/no audio flv segment of black to the original flv to lower the average bitrate of the entire segment so YouTube will let it pass by without re-encoding. -
Originally Posted by filmboss80
Hey 1000 thanks...at least. This is *exactly* the kind of thing I was looking for. Among other things, it lets me cut the bit rate of that dummy video section down to nothing.
The best flv encoder?
By elba in forum Video ConversionReplies: 26Last Post: 7th May 2010, 19:05 -
DirectShow: Precise control of video playback position.
By JCipriani in forum ProgrammingReplies: 4Last Post: 17th Nov 2008, 13:37 -
Stand-alone video resizer/re-encoder with file-size control?
By Brains in forum Video ConversionReplies: 7Last Post: 9th May 2008, 06:30 -
can't install FLV Encoder
By pealia in forum ffmpegX general discussionReplies: 2Last Post: 6th Mar 2008, 11:34 -
Config XviD Encoder to control size
By kevin182h in forum Video ConversionReplies: 6Last Post: 27th Feb 2008, 19:02
