Need help with editing .MOv files when i go to add and merge menu, i select a .mov file, but i cant seem to play it at all, so i cant join the .mov files.... do i need to convert them to .mpegs first? i can convert them right?
I am not aware of a tool that can join mov files. You can convert mov to mpeg and then join them. You will however need the QuickTime plugin for TMPGEnc to convert mov to mpg(check out the software download section of www.doom9.org for a file qtmov.zip)
I downloaded it and installed it, but when I try to preview or convert movies, I can do the first couple of frames then I get an error that reads ***Illegal Floating Decimal Error*** or something like that... any clue/help i can get? thanks
Split/Trim/Join MOV files (works great with Canon SX130's files)
By truchopol in forum EditingReplies: 3Last Post: 27th Jul 2012, 10:35 -
removing background noise in AVI files created from .MOV files
By p_s_92 in forum Newbie / General discussionsReplies: 7Last Post: 23rd Jun 2010, 08:26 -
what is the relation between mp4 files and mov files?
By donaldxdog in forum MacReplies: 3Last Post: 3rd May 2009, 15:28 -
Editing .mov files and .ifo/.vob files
By redhot in forum EditingReplies: 7Last Post: 25th Nov 2008, 07:31 -
About the .srt subtle files and the TMPG DVD Author
By ihmcjacky in forum Authoring (DVD)Replies: 2Last Post: 10th Mar 2008, 10:58
