    Nov 2005
    I double-click the shortcut file but nothing happens. Anyone know what the problem could be?
    BTW, I have WinXP, anti-virus free atm. Is there some special codec I need to have installed prior? I already have the necessary codecs to play an MKV file.
    Are you using windows 2k as your profile says?
    Are you using latest 2.2.3 version?
    I just tried 2.2.3 and it started fine after the installation here on my mac with windows vista with sp1.
    Jun 2007
    Midle East
    have you installed mkv codecs? if dont you can get community codec pack
    from below site.
    http://www.cccp-project.net/
    all the best
    Nov 2005
    Just updated my profile to WinXP SP3 and have have latest 2.2.3 version.
    from below site.
    all the best
    Yes. I have the Lazy man's mkv codec, fddshow and CoreAVC Pro 1.7.
    Nov 2005
    I finally got it to work by installing MS windows script 5.6
