Hi,
i've got following problem:
If I want to muxx an PAL (25fps) AC3 to a NTSC (23,976fps) x264-Video, I have to do a framerateconversion of the audiofiles and i often have to set a delay.
If I use MKVtoolnix to do this (I set delay:123 (or what ever I need) and stretchfactor: 25000/23976) and muxx the AC3 and the video...but then my video is not sync.
But if I set the same delay and stretchfactor in BeSweet and I reencode this and then muxx it with MKVtoolnix everything is fine. But this procedure is not very good because then I'm reencoding a lossy format again....
Now where is the mistake when Im using MKVtoolnix? What does it first? stretching or delaying the movie?
Hi 2 u 2
The "stretch factor", shouldn't it be '23976/25000' instead of '25000/23976'If I use MKVtoolnix to do this (I set delay:123 (or what ever I need) and stretchfactor: 25000/23976)
Convert .FLV without delaying audio to .wmv
By Dailydreamer in forum Video ConversionReplies: 0Last Post: 26th Feb 2012, 15:52 -
MKVtoolnix
By jjis in forum Video ConversionReplies: 0Last Post: 28th Nov 2010, 13:41 -
Delaying parts of an audio stream (vdubmod)
By denadel in forum Newbie / General discussionsReplies: 1Last Post: 24th May 2010, 07:16 -
Transcoding audio -> ffmpeg - besweet - avisynth?
By wiseant in forum AudioReplies: 4Last Post: 18th Dec 2009, 23:14 -
MkvToolNix Help....
By theninger in forum Video ConversionReplies: 9Last Post: 25th Aug 2008, 09:47
