To anyone that can help me here:
I have been usually getting AVI files and they are easy to convert to MPEG, but I have stumbled on what seems to be a hard type of file to convert!!
I recently downloaded two movie files in ASF format, using the recent TMPGEnc it wont convert them, it just stalls then freezes the program, then I have to use the cntr alt del buttom to close it out.
I have checked all settings and all is good for a VCD in NTSC format, I even tried to not use any filters and it still stalls.
I tried to use virtual dub to separate the audio and video files and that program it says wont and does not support ASF format anymore.
Does anyone know what I am doing wrong or a program that will work with ASF files.
I thought that maybe the program TMPGEnc was not working on my PC but I tried a AVI file on my PC and it started to convert it ok.
The ASF files plays perfect with windows media players ok.
Thanks in advance THE DROID.
get virtualdub 1.3c http://perso.wanadoo.fr/nomad/virtualdub13c.zip and you can open asfs and separate the audio
or try asftools repair or convert to avi www.vcdhelp.com/vcdtools.htm
need help converting .asf to h264 .mp4
By hydra3333 in forum Video ConversionReplies: 3Last Post: 12th Sep 2010, 07:53 -
Converting .ASF files to editable format
By carbongixxer in forum Video ConversionReplies: 2Last Post: 10th Nov 2009, 13:37 -
By carbongixxer in forum MacReplies: 0Last Post: 10th Nov 2009, 12:50 -
converting asf to avi
By projecttemp in forum Video ConversionReplies: 2Last Post: 3rd Aug 2008, 08:40 -
Converting an ASF (WMV) file
By yadda in forum Newbie / General discussionsReplies: 1Last Post: 7th Nov 2007, 06:16
