My five month old 'A4 Tech' optical (PS2) mouse is dragging the curser, occasionally, you know where you move the mouse and the curser stays behind and you have to jiggle the mouse to wake the curser up !
I've been considering one of these 'lazer' versions (1800dpi etc) . Does anyone know, are they better than the standard LED versions ? Are thy worth the extra cost ? I read somewhere they are mostly gaming mice for some reason, but howabout for normal everyday use ?
Results 1 to 13 of 13
Originally Posted by cyflyerRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Yeah really fine control stuff only. I use a standard one and love it. Who needs that much fine control. Its just a mouse.
Ive had a Logitech G5 for a couple of years, and love it. Very precise motion, works on most surfaces, and no annoying habits. I use it mainly for non-game applications.
That being said, the LED mouse that I salvaged from a dumpster works nearly as well for most stuff. It's not as precise but it's quite adequate. -
Originally Posted by JohnnyMalaria
The other thing I noticed on the Lazer mouse blurb is that you can adjust from 2000 to 1000 to 800 dpi reading sensitivity, but why would you want to do that ? How can it be too precise ? -
On the subject of optical mouse, is there one that can work on a glass table ?
Originally Posted by Sing-Sing
SingSing you could always get one that doesn't require a table
http://www.microdirect.co.uk/ProductInfo.aspx?ProductID=12492 -
Originally Posted by fatbloke88
Mouse problem = looking for new mouse.
By Stealth3si in forum ComputerReplies: 14Last Post: 12th Nov 2011, 04:25 -
LCD or LED
By hardy in forum Off topicReplies: 5Last Post: 7th Jan 2011, 11:37 -
Media player verses htpc
By Marccc in forum Media Center PC / MediaCentersReplies: 2Last Post: 15th May 2010, 08:10 -
STANDARD BONEHEAD REPLY FORM (version 3,643.7)
By Feslmogh in forum Off topicReplies: 16Last Post: 9th Apr 2009, 17:30 -
Roxio Easy Media Creator 10 verses Pinnacle Studio 11
By snuggels in forum Newbie / General discussionsReplies: 3Last Post: 3rd Oct 2007, 12:10
