thanks
And...
What kind of cutting do you want to do? Trim it? Chop it into individual pieces?
The more you tell... the longer and better the answer.
Easiest way to cut and join video files
By zammil in forum Newbie / General discussionsReplies: 8Last Post: 15th Oct 2010, 13:04 -
What's the quickest/easiest way to cut something from DVD and DivX
By dsajkw in forum EditingReplies: 2Last Post: 2nd Sep 2010, 12:50 -
Easiest software to convert Dual Audio/Subtitle MKV to WMV or AVI
By greasyspoon in forum Video ConversionReplies: 1Last Post: 9th Sep 2009, 13:43 -
Easiest way to mix different audio into .avi video file?
By BertRito in forum AudioReplies: 4Last Post: 21st May 2008, 23:57 -
best, easiest way to cut bad section out of vob file
By dblake2 in forum EditingReplies: 2Last Post: 16th May 2008, 18:53
