Do most DVD players play WMV/A files?
Results 1 to 11 of 11
Most DVD players? Nope. Many newer ones offer that feature, but it is not standard on most DVD players, AFAIK.
So if you were to put a WMV file on a blank DVD, the player wont read it?
not very likely any will read it.
But they all will most definitely read a MPEG1 file? Just making sure.
most players used to read mpeg-1 written as vcd on a cd. not an mpeg-1 file copied to a cd. i'd guess most still play vcds but very few vcds are made because of the very poor quality of the video specs.
MPEG-1/2 authored as DVD-Video: yes;But they all will most definitely read a MPEG1 file? Just making sure.
MPEG-1/2 authored as VCD: probably;
MPEG-1/2 authored as SVCD: possibly;
MPEG-1/2 in a data CD/DVD: depends. -
MPEG-1/2 authored as VCD: probably; <<not if it's mpeg-2>>
MPEG-1/2 authored as SVCD: possibly; <<not if it's mpeg-1>>
if you take that mpeg-1 and author it to a vcd with something like vcdeasy and burn to a cd then most players should handle it.--
aedipuss wrote:
Apologies. I had ignored the fact that the OP lives in the United States.MPEG-1/2 authored as VCD: probably; <<not if it's mpeg-2>>
Movie_LeftEye.wmv + Movie_RightEye.wmv + Polarized glasses = ?
By barelief in forum Authoring (Blu-ray)Replies: 0Last Post: 21st Nov 2011, 16:45 -
combining WMV movie clips into one WMV clip
By blkwht240 in forum EditingReplies: 3Last Post: 5th Feb 2010, 01:41 -
1080p WMV to 720p WMV?
By TekMerc in forum Video ConversionReplies: 4Last Post: 7th Jan 2009, 15:41 -
How to convert wmv clip so its properties match other wmv clips
By sohaibrazzaq in forum Video ConversionReplies: 4Last Post: 4th Aug 2007, 10:16 -
.flv to .wmv or wmv. to mpg
By LITEONDVD in forum Video ConversionReplies: 5Last Post: 29th Jul 2007, 19:02
