I'm trying to edit a video in this program, and I need to know how to do the following:
I have a character who moves through the background, behind some columns. What can I do to actually make this character look like it's going behind the columns? Is there some technique for this, and what is it? Please keep in mind that I'm just a beginner at this. Thank you.
What footage do you have ?
If you have footage of someone walking behind columns, these isn't a lot you can do. You can try to mask the columns onto a new layer, then blur them to give a faux depth of field effect, but that is about it.
If you have footage of someone walking across the screen then you can create a new layer with columns, ad some blur and even a slight sideways movement to fake a parallax effect.
You need to provide far more detail and even a short sample of the footage if you want a more detailed answer.Read my blog here.
Well, unfortunately, I can't provide a sample because I promised the person I'm doing it for that I wouldn't share it until it's finished... but I can provide an example. Look at :32 in the following movie:Originally Posted by guns1inger
http://youtube.com/watch?v=PyWe1T86nq0
See how they got Luigi to pop up like that, even though the background is solid? With that in mind, I want to make that character (which I'm animating myself) walk behind the columns without making it look cheesy.
Is there a mask or something that I can put at the location of the column that will hide the character when it walks past, but not affect the background footage? I think that's what happened in this video.[/i] -
I am no AE guru, but this is not difficult to do. The following is assuming you have a static background.
Begin by masking out the column(s) from the background by using the pen tool. Do this for each column that you want the subject to walk behind. You will have to duplicate the layer and apply a mask for each column. You will also need to have the original background as the bottom layer. Make sure that the moving character is positioned BEHIND the columns, but on TOP of the background. Position and size the character as needed. That's it!
Here is a link to a quick sample that I did in under 10 minutes:
http://www.digitalmemoriestn.com/downloads/mousewalk.wmv
Brainiac
No depth in SBS 3D to ColorCode 3D
By BaltarWithSix in forum Video ConversionReplies: 0Last Post: 21st Jan 2012, 18:18 -
Thin depth of field...?
By thiskey in forum Newbie / General discussionsReplies: 8Last Post: 19th Oct 2010, 12:12 -
What is the best special effects/visual effects software?
By dzsoul in forum EditingReplies: 37Last Post: 9th Aug 2010, 23:16 -
After Effects: copy effects to another composition?
By squadjot in forum EditingReplies: 2Last Post: 8th Dec 2009, 19:16 -
Color Depth
By gingka in forum Video ConversionReplies: 4Last Post: 20th Aug 2009, 21:53
