Hi,
My question is very simple.
I have 2 subtitles of indiana jones the temple of doom, one of them in some strange language has the correct timing of the lines, and the second one (in my language) have incorrect timing on each lline. I would like to correct the timing of the second one, by replacing the timings of the strange-language subtitle.
Im using subtitle workshop, but the option "adjust to synchronized subtitles" doesnt seems to work.
Hope some can help me!
I uploaded both subtitles here:
http://www.mediafire.com/?2myjucjtvyd
	HTH.2.6 Read times from file
 Useful if you have one subtitle file in which the text of each subtitle is right but the timings are not, and you have another file with the same number of subtitles and with the right times. You just have to load the file with the right texts, and then click the "Edit/Timings/Read timings from file" menu or press the [Shift]+[Ctrl]+[T] keys. A dialog will pop up, all you have to do is select the file with the right times in that dialog and load it.
	You can also always try to find a better subtitle file. Some of the ones mentioned in the post below might be a decent starting point... I don't know, as I haven't tried them.
 https://forum.videohelp.com/topic331069.htmlIf cameras add ten pounds, why would people want to eat them?
  Keeping subtitles in 2 lines from original .txt file in Subtitle WorkshopBy Valerc in forum SubtitleReplies: 3Last Post: 10th Feb 2012, 07:45
  FAVC Subtitles Number of LinesBy niknik in forum Video ConversionReplies: 0Last Post: 19th May 2010, 00:37
  Deleting some lines from subtitles but how to get the rest in sync?By UmmAddan in forum SubtitleReplies: 4Last Post: 21st Aug 2009, 09:09
  Untidy lines in subtitles (.SUP)By jiles in forum SubtitleReplies: 17Last Post: 1st Aug 2009, 02:43
  Diagonal lines with subtitlesBy arnie22112000 in forum SubtitleReplies: 0Last Post: 8th Mar 2008, 07:11
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
