i had a similar problem ended up the laser went bad ordered NEW from panasonic so i thought,they sent a rebuilt one and said it was new ,you could tell from the rub marks on the screw holes and drive .It gets better I find a note in the box that they want the old drive back or ready for this a core charge will be applied to my card ? now i don't know about any body else but when i order new and pay a premium price i expect new with no core charge. I called them and explained the problem the girl said oh you want a new one i said well yes thats what i paid for she made a note on my acct and another about o core sent a shipping return label but will not send a new one until they get that one back ummm they have my cc number? poor business practices from them this is just a fyi to watch what you get look at it closely and complain .
Results 31 to 33 of 33
JJeff's up/down channel reset fixed my problem. I record on DVDRW disks, then insert disk in my laptop - copy the raw video over, (then edit with MPEG Video Wizard).
Anyway on the Panasonic, I was suddenly getting the message "UNFORMAT" on the front panel. Attempting to format resulted in "failed format". I thought it was my old scratched up disks until getting the same result from new ones. Then found the post on how to reset by holding up/down channel buttons for 10 seconds. Presto!
Thanks folks!Last edited by CartoonVideo; 22nd Feb 2013 at 19:22.
I had my DMR-EZ37V for about 5 years and hadn't had time to use it. I just pulled it out and the DVD would not read. What I found once I took the top off the machine and then the top off DVD, was the packing ring was still in the DVD. I removed it and it worked like a champ.
Panasonic DMR-ES35V
By RobJenk in forum DVD & Blu-ray RecordersReplies: 0Last Post: 16th Dec 2010, 13:42 -
use Panasonic DMR-ES35V with universal remote?
By kar120c in forum DVD & Blu-ray RecordersReplies: 1Last Post: 29th Sep 2010, 14:14 -
Panasonic DMR-ES35V "Self-Check Failed," refuses to run
By MattOKC in forum DVD & Blu-ray RecordersReplies: 2Last Post: 5th Jul 2010, 17:50 -
Panasonic DVD Recorder-VCR Combo unit model "DMR-ES35V"
By Syd Jamal in forum DVD & Blu-ray RecordersReplies: 4Last Post: 17th Jan 2010, 15:27 -
help for PANASONIC DMR-ES35V ......PLEASE!!!!
By samjc2007 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 7th Jul 2007, 11:35
