Hi,
I have a strange issue that I'd like some advice. I have some DVDs that were created by recording TV shows using my Liteon DVD recorder. I used to always play them back on the same machine (Liteon) without issue.
Now I have started to use an olidsh (5 years old) JVC and after one or two second of "normal picture" the TV starts to show two images (maybe the interlaced images) side by side on the same screen.
Any ideas where to start. Normal DVDs (i.e. store bought) are fine, it is just the DVD recorded ones (they look fine on a PC and on the original machine).
Perhaps it is a case of progressive vs interlaced? Any ideas would be helpful.
Thanks,
lmcnlcy
	I don't think it's a interlaced problem. The old player may have some problems with burned media. Maybe you could try copy the recording to a different dvdr media.
	I have a JVC player of about the same vintage. For the most part, it does a good job, but every now and then, I'll burn a disc it won't play at all - just acts as if there's not even a disc in the machine.
 None of my other players do this, so I've written it off as "squirreliness" specific to the machine. You might be seeing something similar.
  Double-sided, double-layer. Are they the same thing?By ibzomie in forum MediaReplies: 8Last Post: 5th Feb 2011, 17:13
  MPC HC x64 double images/videos since svn 1503? (pix attached)By tigerb in forum Newbie / General discussionsReplies: 2Last Post: 21st Jan 2010, 08:30
  best camcorder for best dvd resultsBy syeager in forum Newbie / General discussionsReplies: 16Last Post: 23rd Oct 2008, 00:28
  Double Layer DVDBy nagihcim1 in forum Newbie / General discussionsReplies: 1Last Post: 7th Sep 2007, 20:09
  Double DVD CasesBy royal007 in forum MediaReplies: 0Last Post: 16th Aug 2007, 19:45
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
