I have checked DVD Flick which I've found very good. As the latest beta also allows menus, the only thing it still lacks is the option to add titles between the videos or at least a 'title page' at the start of the disc. Is there a comparable tool - preferably free - allowing to insert titles which you recommend ?
Thank you.
DVD Styler or GUIForDVDAuthor...but they are not all-in-one converters like dvd flick so you have to convert using separate tools.
If you want something that do everything I don't think you will find any free software for that. -
I think he means Menu instead of Title Page. Edit: Nope, he mentions menus. Geez, I think he wants to key some titles at the head of each video segment. Heck, I don't know. Leo, can you be more specific?
When you start a DVD, it usually shows a 'Walt Disney presents ...' or the like start page. And if you put several video files on a disc, you would like to insert a 'Little Suzy in Disneyland' or 'Grandpa's 99th Birthday' in front of every track.Originally Posted by Midzuki
It seems DVD Flick, otherwise a great tool, does not provide that (Windows movie maker does, but is otherwise insufficient in most respects). -
I see. You want a brief introduction clip, or an introduction menu,
before each movie(or rather, "title"). As Baldrick said,
GUI4DVDAuthor or DVDStyler are the freeware tools for the job.
You might also manage to use use DVD-lab before its trial period expires.
Disc writing tool not working in TMPGEnc dvd authoring 4
By egor909 in forum Authoring (DVD)Replies: 3Last Post: 22nd Nov 2009, 05:14 -
authoring tool for HD video -> DVD
By feh in forum Authoring (DVD)Replies: 2Last Post: 13th Jan 2009, 14:03 -
newbie question: need freeware DVD authoring tool
By kbflower in forum Authoring (DVD)Replies: 7Last Post: 20th Jul 2008, 20:45 -
Which DVD Authoring tool to use?
By jodajen2 in forum Authoring (DVD)Replies: 6Last Post: 14th Nov 2007, 09:21 -
How do I do this with Sizzle (dvd authoring tool)?
By master_debator in forum MacReplies: 0Last Post: 27th Aug 2007, 13:45
