Hi,
I'm a nooB trying to encode some Quicktime .MOV files into DIVX AVIs and I cannot edit any of the parameters in the video tab. If I try to change the frame size or the bitrate or anything else I get an Applescript Error:
I'm running OS X 10.4.11 on a Quad G5 2.5 GHz with 4.5 GB RAM. My Quicktime version is 7.4.5
Please help!
At first sight this seems to be an error related to an empty (or only a space character? in a) numerical field.
The latest version (0.0.9y) has seen some AppleScript errors that previous versions didn't show. Most notably "The variable _iframeflag is not defined. (-2753)" when using the Bitrate Calculator with ffmpeg presets (but not for mencoder presets).
a. Check for empty fields (or fields with a space character) that should have a number.
If that doesn't help:
b. Try a mencoder preset.
Let us know how that turns out.
divx 2pass encode error
By ledishis in forum Video ConversionReplies: 3Last Post: 4th Apr 2012, 14:47 -
Error message when trying to encode one file using AVStoDVD Program
By spritely in forum Video ConversionReplies: 3Last Post: 25th May 2011, 11:52 -
Strange message at installation
By sd1936 in forum ffmpegX general discussionReplies: 1Last Post: 28th Sep 2008, 07:46 -
Error message in TMPGEnc 3 with Divx Authoring...
By blasedeviant in forum Newbie / General discussionsReplies: 5Last Post: 22nd Apr 2008, 13:29 -
Strange error message when re-authoring with TMPEGEnc DVD Author 1.6...
By justin81 in forum Authoring (DVD)Replies: 3Last Post: 24th Sep 2007, 01:23
