Hi.
I've taken some files from my harddrive dvd player (Ellion) and used Nero digital to recode them as mp4. My Ellion manual says that I can copy files from an "mp4 disc" to the hdd. I took this as meaning mp4 files on a data dvd. So, when I made a data disc with mp4 files, I thought they should be picked up by the player, but not so. A friend of mine recently gave me a disc with avi files on it, and they can be read (but not copied to hdd).
According to Nero, when you use Recode, the resulting output is mpeg-4 files, and sure enough they have the mp4 file extension. Should I try using divx (or similar) instead? Is there an inherent glitch in using Nero Recode?
Thanks.
After reading your post, I remembered this post from yesterday: https://forum.videohelp.com/topic350164.html
Which seems to indicate the mp4 container can use various formats. It is then likely, as in the post above, that your player doesn't support all mp4 files. Which is typical of standalone players, there are too many various encoding options to support them all.
I would suggest checking the working and non-working files and seeing what is different.Google is your Friend -
Thanks for that. Is there a concensus out there that some of the formats, within the mp4 container, are more reliable than others? Would, say, divx be recommended over XviD?
Thanks in advance. -
Quality aside, none will be more "reliable" than another. It's all a matter of using the format which meets your needs.
Playing HD MP4 Files From Disc Playback Issues?
By zombie1 in forum DVD & Blu-ray WritersReplies: 5Last Post: 5th Nov 2011, 12:41 -
Merging and converting H.264 mp4 HD files from Samsung HMX-H204?
By guy24s in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 18th Jun 2011, 07:41 -
Creating an AVCHD disc from Sony camera files (MP4)?
By Dshow in forum Authoring (Blu-ray)Replies: 6Last Post: 11th Apr 2011, 18:01 -
Converting VOB files from Sony HandyCam to MP4 or MOV
By electrox73 in forum DVD RippingReplies: 3Last Post: 8th Jan 2011, 06:46 -
Converting mp4 files to avi files
By HartsVideo in forum AudioReplies: 1Last Post: 18th Jul 2008, 19:20
