I have a Sony blu-ray IDE burner that was working fine in my old computer. When installed in new computer, it will not recognize a blu-ray disc. It will read DVDs. Switching it back to the old computer, it works fine.
Old computer: Gigabyte mobo, P4 2.6g cpu, 2 gig ram, XP Pro sp2.
New computer: Gigabyte GA-P35-DS3L, Q6600 cpu, 2 gig ram, XP Pro sp2.
Any suggestions?
Did you set the sony blu-ray ide burner to master or slave? check the jumper on the back of the drive and set to either master or slave. Are you using a 80 wire ide cable?
If your Blu-Ray burner is a SATA model, you might try it in a different SATA socket. What software are you using for Blu-Ray playback? Same on both computers? Same type video card?
Seems the OP has the first generation Sony Blu-ray IDE Burner, model BWU-100A IDE Internal Blu-ray Burner.
The newer Sony Blu-ray Internal Blu-ray Dvd Burner model BWU-200S is SATA.
LG BH10LS30 blu ray burner, Doesnt seem to recognise blu ray media
By john8611 in forum DVD & Blu-ray WritersReplies: 11Last Post: 5th Feb 2012, 04:58 -
ps3 blu ray not working
By joeyg720 in forum Newbie / General discussionsReplies: 9Last Post: 27th Jul 2011, 05:47 -
DVDFAB Blu ray to blu ray free version stopped working
By kohlirowe in forum Blu-ray RippingReplies: 3Last Post: 5th Jul 2010, 11:50 -
Are there any 100% working methods for Blu-ray TO Blu-ray ?
By Tyrexionibus in forum Blu-ray RippingReplies: 8Last Post: 19th Oct 2009, 09:55 -
Blu Ray burner help
By dafoe in forum DVD & Blu-ray WritersReplies: 11Last Post: 8th Apr 2009, 01:14
All the ones I've seen are SATA.
