I made a DTS WAV out of DTS Surcode but whenever I try to play it I only hear static. So then I decide to burn my video with the audio on a DVD so I can try it on my DTS compatible speakers but with no avail, static again. I have the speakers connected to my PS3 and have been able to play blu-ray movies with DTS audio without any problems. Is it an encoding problem? I used the V.I. plug-in in Sound Forge to create my 6 WAV files encoded at 24 bit (I also tried 16 bit) fed to DTS Surcode. Is there some sort of way I can check if the DTS WAV is all right by decoding it and then playing it or something? I want to make sure everything is ok with it on my computer first before I decide to risk damaging my speakers again.
Results 1 to 15 of 15
Run it through DTSParser
http://forum.doom9.org/attachment.php?attachmentid=7972&d=1199902229 -
So I just run it through DTS Parser and that's all?
The DVD-Video specs require "pure" DTS.
Surcode can output both "pure" DTS streams and .WAV-wrapped~DTS.
The user is allowed to choose which format is best for their needs. smile.gif -
DTS audio data can be stored in three different data file: Compact (*.cpt), Padded (*.dts), and Wave
(.wav). Each of these has its uses. DVD authoring systems vary in their handling of these file formats, but
in general:
• Compact (*.cpt) file format is the one most used for DVD authoring.
• Some systems also accept files in the Padded (*.dts) format.
• .wav format files are useful for quality assurance because .wav is a standardized digital audio
file format playable on a variety of digital audio systems. .wav format files are not used
directly for authoring.
Authoring systems vary in the way they handle these file types, and encoding systems also vary in the
way they are specified. The specifics of individual systems are described later in this document.
Compact (*.cpt) File Format
Encoding systems for DTS provide a default or option to save files in the Compact format with the file
extension “.cpt”. Compact format files are encoded with only audio, timecode, and header information,
and are coded in “Motorola” (high-order byte first) byte order.
Not all DVD authoring systems recognize the “.cpt” extension. Depending on the system, you may have
to set the list of file types displayed in the Open File dialog to “All Files” in order to see the *.cpt files. In
certain cases, you may have rename files to “.dts” in the file system in order to use Compact format files
in authoring.
Padded (*.dts) File Format
Most of systems for encoding to DTS define the option of Padded (*.dts) file type by selecting this
extension when the file is saved. Some systems define this as an option in encoding labeled as “Pad Files
with Zeroes”, or similar wording. “Padded” files include extra zeroes in addition to the audio payload and
timecode/header information. These files are stored in Motorola byte order.
Most DVD authoring systems are able to use both Padded and Compact file types.
.wav File Format
All DTS encoding systems provide option to save in “.wav” format, consisting of padded audio data
stored in “Intel” (low-order byte first) byte order. These are identical in format to ordinary audio .wav
files, can be handled by standard digital audio application, and can be played in various ways.
This file type is not used directly in DVD authoring, but is often useful for auditioning. Some encoding
systems provide an option to generate separate *.wav files automatically for this purpose. -
Unfortunately I'm using DVD Architect and it has no DTS support. If I import a WAV DTS it's still going to be static. What software can I use to mux AC3 and/or DTS streams? I've tried Muxman but always get an error when trying to mux DTS. I've read somewhere that ImagoMPEG-Muxer can mux DTS streams but I have yet to find that option.
dvd-lab pro might work. it accepts normal dts, but i've never tried dts wav.
media player classic will play dts wav files. other dvd software should also.--
Time to try DVD-lab Pro, I guess.
If I import a WAV DTS it's still going to be static.. Your DVD player must output the WAV-wrapped "noise"
onto an external digital-audio amplifier.
I've tried Muxman but always get an error when trying to mux DTS. -
I've tried it with compact and padded DTS and the error shows: "Multiplex operation failed. Probably caused by excessive bitrate".
Is it referring to the system bitrate? I don't understand why I would get that message even when the total data rate is only about 8mbs.
Time to try DVD-lab Pro, I guess. -
Problem with DVD-lab Pro is it's not free. -
If it can support DTS then I'll just use it to mux my audio and author with DVD Architect. Thanks, I'll try it out.
Now you know what my current sigfile is all about.
I can't play back .m2ts files with DTS audio
By Quadcam in forum Blu-ray RippingReplies: 3Last Post: 24th Nov 2011, 16:31 -
help gettinng .m2ts with dts to play on ps3 with the dts intact. got close
By jayjay139 in forum Blu-ray RippingReplies: 0Last Post: 12th Mar 2010, 12:10 -
I have a problem, player cant play DTS... need to convert
By Chrushev in forum Authoring (DVD)Replies: 1Last Post: 25th Oct 2009, 02:56 -
How to burn/play DTS audio cd's
By arraf in forum AudioReplies: 16Last Post: 9th Sep 2009, 12:55 -
Ripping & DTS play problem
By Serville in forum DVD RippingReplies: 0Last Post: 23rd Apr 2009, 09:00
