I am wanting to create an online tutorial. I am capturing using screen capture software called iShowU which is quite good.
Ideally I would like to produce the same quality and size as the PhotoshopUserTV webcast ( http://www.photoshopusertv.com/ )
How do I render out for good quality, yet not too big a file size?
Thanks,,
ps: iShowU can render in a variety of formats. The audio is set to high quality and the codec is H264.
It creates MOV files.
Maybe try another screen capture tool like wink, it can also export directly to flash video with good quality and small file size.
If you prefer ishowu then I would consider getting flash professional or on2 flash encoder for good qualith flash video. -
Thanks,, I have Final Cut Studio 2 (latest ver of Final Cut Pro, Compressor etc).
Can this expensive beasty not do something. I have Sony Vegas at home on my PC. -
I don't use those beasts so I don't know...but I'm pretty sure a google search would tell you.
VFW ffdshow Settings to Edit flv in Vdub
By kaskaļ in forum Newbie / General discussionsReplies: 15Last Post: 1st Jun 2011, 12:40 -
Flv streaming from my site stutters on some computers Here are my settings
By doz in forum Video Streaming DownloadingReplies: 2Last Post: 16th Nov 2009, 13:09 -
FLV to Avi or MPG, recommended settings?
By dzoni in forum Video ConversionReplies: 1Last Post: 12th Sep 2008, 16:27 -
AviDemux settings for flv to mpeg
By ecc in forum Video ConversionReplies: 0Last Post: 2nd Apr 2008, 05:45 -
What's the best FLV converter + best method to create FLV's from pure video
By OM2 in forum Newbie / General discussionsReplies: 7Last Post: 31st Mar 2008, 20:23
