I just downloaded the trial version of Cinema Craft SP 2.7 and when I drop my QT Ref into CC SP 2.7, I recieved this error:
Frame size 1920x1080 is not supported
Is CC SP 2.7 not supporting encoding HD contents? I want to encode my HD contents QT Ref file into DVD compatible format so that I can burn them into DVD. Is this error relates to the fact that this is a trial version?
Results 1 to 11 of 11
no version of CCE has ever supported HD. try procoder3 or mainconcept reference.
Ah, I see. So this software is close to $2,000 but cannot encode HD content? The price seems quite steep for an encoder that cannot encode HD.
Anyway, thanks for all your responses. -
If you mean SD DVD for output, you can use CCE SP2 version which supports HD resolution as input:Originally Posted by ljCharlie
http://www.cinemacraft.com/eng/if2006063002.html -
So, just how much did you pay for your copy? It seems to me that if you were about to fork over $2,000 for it you'd learn about what it can and can't do.Originally Posted by ljCharlie
manomo - he wrote it's the trial version. they still have those you know.
http://www.cinemacraft.com/eng/download.html#basic--
If you are converting HD to SD you can use CCE but you have to resize first. You can use AviSynth to do this -- CCE accepts AviSynth scripts.
Otherwise, the SD limitations are to force you to pay even more for the HD version. TMPGEnc Plus is very old and slow but can encode at HD resolutions. -
LOL....You should see the price tags of encoders which do HDSo, just how much did you pay for your copy? It seems to me that if you were about to fork over $2,000 for it you'd learn about what it can and can't do.
Cinemacraft's HD encoder sets you back about 60K
[quote="videopoo"]
and it still won't do 50/60pLOL....You should see the price tags of encoders which do HD
Frame Size
By kamranj in forum Newbie / General discussionsReplies: 18Last Post: 9th Jan 2011, 18:59 -
Frame Size. What effect does it have?
By happydog500 in forum Capturing and VCRReplies: 7Last Post: 12th Mar 2009, 00:21 -
Frame size in HDVSplit
By kippard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 5th May 2008, 00:36 -
Avi not divx-supported size?
By chirufan in forum SubtitleReplies: 21Last Post: 8th Mar 2008, 04:35 -
Is there a list of all supported files supported by svcd2dvd ?
By geek2330 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 19th Oct 2007, 11:07
