hi
i need a tools to split a large mpeg1 file into sizes that fit in VCD's with the following characteristics:
1. i prefer it not to have any additional option and does nothing more, eg. recognizes .avi files, be able to convert formats, etc. i need it just to split.
2. a standard VCD may fit 4779 seconds of video or a value about it. i need it to really fit as much as possible and don't care the second part becomes small.
3. do not re-encode! the original mpeg1 file is already encoded and don't need to be re-encoded. i need it just to split! so it must save the original file's format. for example i may have made an effort to make it too VCD compliant and i don't want it to be re-encoded. something like VCDCutter don't keep the original format.
4. not to be visual. TMPGEnc does this but this tools is visual.
5. be fast. TMPGEnc is not.
6. do not ask for the output format. because it must be the same as the original one.
why ppl r not used to write simple&useful programs? they write programs with lots of features which does everything but what someone may really need, although this may be a very simple task!
thanx if someone may help
If a lot of people really did need it, someone would write it. Yours is not a common request.
If your intention to author these parts into individual VCDs ?
Also, cutting would not be frame accurate, but limited to nearest key-frame, otherwise some encoding would have to occur.Read my blog here.
Take a look at mpgtx (Google for it) - it can split a file by time or file size.
/Mats
How Cut MKV
By mmkk in forum Video ConversionReplies: 8Last Post: 7th Jun 2010, 12:24 -
mp3direct cut
By RustyBob in forum AudioReplies: 11Last Post: 2nd Jun 2010, 20:50 -
Cut and Join VCD Files: tools that can Handle that
By devilcoelhodog in forum Authoring (VCD/SVCD)Replies: 5Last Post: 15th Jan 2010, 21:57 -
how to cut....
By marlo in forum Newbie / General discussionsReplies: 3Last Post: 27th Jan 2008, 02:28 -
final cut express and final cut pro 6
By ednarophati in forum MacReplies: 1Last Post: 16th Jul 2007, 10:05
