    Dec 2007
    hey guys, i've been ripping entourage stuff from seasons 1 and 2. but i just got to season 3 (pt1) and its not working right.
    im using DVDFab platinum. seasons 1 and 2 work perfectly, but whenever i pop in season 3 (any disk of s3) the thing that comes up on dvdfab and tells u its reading the disk or whatever never stops. i guess this is some kind of protection? but i cant figure it out
    is anyone else having problems like this?
    Oct 2005
    666th portal
    update to latest beta version of dvdfab?
    Dec 2007
    yeh i have, its at v 4.1.2.0
    Oct 2005
    666th portal
    i think they're at v5.0.1.0
    Dec 2007
    well damn, the one i got from here gave me 4.1.2.0
    well thanks.. ill try and see if the newer one works.
    thanks
    Dec 2007
    alright, well failed. its still not working
    Oct 2005
    666th portal
    you might try anydvd.
    Dec 2007
    alright yeh, anydvd seemed like it was working fine
    it created some vobs that worked just fine.
    im still gonna try and hunt down some stuff about why dvdfab isnt working
    thanks for the help!
    EDIT:PROBLEM RESOLVED:
    just had to turn off pathplayer in settings
    fingers crossed it rips correctly
