not sure if i'm in the right place here, but i have an editing question.
i want to make a (very modest) music video. i plan to make 5 shots of 4 separate musicians and one with the entire band. i will end up with 5 mpeg video's on my camera (sony dcr-sr32e). how can i edit these 5 shots together? i have no idea how to get audio and video in sync. i could do it manually, with a lot of guesswork and a guaranteed shitty result, or i could use suggestions from you people. i'm not so much bothered about which editing software to use. i think it's a question of recording each shot with time code. is there a hidden time code on mpegs? if so, how do i read it?
Results 1 to 13 of 13
This would normally be done with 5 cameras. Is this what you are doing?
Recording 5 performances with one camcorder will allow only approximate audio sync with manual video positioning against a single audio track.
For multi-cam, expect non-genlocked camcorders to run at slightly different speeds. This means more manual tweaking.
You will need an edit program that displays the waveforms and allows sub frame editing for audio. Typical prosumer edit programs allow 8 to 16 subframe accuracy.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
hell no! i have one camera that would have to record the performance 5 times in a row, not at once."Is this what you are doing?"
how much is "approximate"? if the result is 1/4 second difference/time lag between audio and video, i might just accept that. if it's more like 1 full second time lag, the result would be ridiculous.Recording 5 performances with one camcorder will allow only approximate audio sync with manual video positioning against a single audio track.
it's more of an experiment, not a job worth paying for. but what if every shot in the final edit is 2 seconds long? that editing job with what you call "manual tweaking" could take days!
uhm, what does this mean in simple english?Typical prosumer edit programs allow 8 to 16 subframe accuracy. -
If you have the band members individually and collectively lip sync to a prerecorded tape of theirs, then use that for your audio track, it might be a bit easier. Then you just have to sync the individual videos to your prerecorded track. It's a bit of work, but you should be able to make it look fairly close to a multi camera setup. Careful planning of your shots and diagramming it all out in advance may help. Either way, I hope they have a lot of patience, as this may take a while to record. Just one suggestion.
that would be an option... in theory. the band plays heavy metal and those people are not keen on lipsynching. we're not talking about ashlee simpson here!
http://www.ew.com/ew/article/0,,735566,00.html
having them sing & play live and recording that is another option but that would result in one long and boring shot. would anyone want to want a 4 minute song without any edits? -
Yes easily. You need to try this to learn the difficulties. Syncing audio is about as frustrating as editing gets.Originally Posted by Noobmeister
Each frame of video lasts 1/30th second. Those looking for tight lip sync or sound effects matching want 1/240th to 1/480th second sync precision, hence 8 to 16 sound edit points within a frame.Recommends: Kiva.org - Loans that change lives.
shoot each performer and wide angle for a total of 5 complete songs
pick which version of the song they like best
demux and place on timeline
now you can insert each performer's video and the band's wide angle to the audio timeline
you can always fine tune the sync to audio by speeding/slowing the video frame rate -
@ zoobie
i might try it that way!
@ edDV
i believe that is ntsc. i'm using pal which is 1/25.Each frame of video lasts 1/30th second -
I didn't know they used PAL on Mars.
True, with the exception of the extreme southern regions where they use LAP.Originally Posted by guns1inger
Not to mention that PAL is not supported in the United States of Mars.
The original Nasa Moon camera was made by Westinghouse and operated 60 fields per second.Originally Posted by MidzukiRecommends: Kiva.org - Loans that change lives.
VOB Editing question
By jeffboyrd in forum Newbie / General discussionsReplies: 4Last Post: 9th Oct 2010, 10:47 -
Question About on the Fly Editing
By guarddog in forum EditingReplies: 1Last Post: 29th Jan 2010, 03:07 -
editing stage question
By ht0160 in forum EditingReplies: 3Last Post: 2nd Jun 2008, 11:04 -
Question about editing TV recordings
By gastrof in forum Authoring (DVD)Replies: 4Last Post: 9th Feb 2008, 11:51 -
Question About Video Only Editing
By greyhavens49420 in forum EditingReplies: 1Last Post: 1st Feb 2008, 01:18
