I've played with various frame rates, but haven't been able to get ffmpegX to actually start encoding my RMVB file -- I'm obviously doing something wrong but even with the help of the numerous posts here, have not been able to figure it out.
According to ffmpegX, format of the video in my source file is: RV40, 640x352, 23.000 fps. Current target video format window reads: mencoder mpeg4, 640x352, 1163 kbps, 23.000 fps, no crop.
I get endless frame skipping (with occasional notes on individual frames).
Very grateful for your help (and patience!).
	Addendum to previous:
 Looking at Progress log, found the following, which I should've included in my original post (sorry!):
 Opening video filter: [expand osd=1]
 Error: dlopen(/Library/Application Support/ffmpegX/reallib/drvc.so, 1): no suitable image found. Did find:
 /Library/Application Support/ffmpegX/reallib/drvc.so: unknown file type, first eight bytes: 0x7F 0x45 0x4C 0x46 0x01 0x01 0x01 0x00
 Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
 Opening video filter: [scale w=640 h=352]
 Opening video decoder: [realvid] RealVideo decoder
 Read the RealVideo section of the DOCS!
 VDecoder init failed
 Error: dlopen(/Library/Application Support/ffmpegX/reallib/drv4.so.6.0, 1): image not found
 it failed
 Selected video codec: [rv40mac] vfm: realvid (Mac OS X RealPlayer 9 RV40 decoder)
 Forcing output fourcc to 58564944 [DIVX]
 MP3 audio selected
 VDec: vo config request - 640 x 352 (preferred colorspace: Planar I420)
 VDec: using Planar I420 as output csp (no 0)
 Movie-Aspect is 1.82:1 - prescaling to correct movie aspect.
 SwScaler: using unscaled Planar YV12 -> Planar YV12 special converter
 videocodec: libavcodec (640x352 fourcc=58564944 [DIVX])
 Writing header...
 ODML: Aspect information not (yet?) available or unspecified, not writing vprp header.
 Writing header...
 Skipping frame!
 Skipping frame!
 Skipping frame!
 etc, etc
 Thanks.
	Jean-Philippe Schuck
 Un générique, un autre jour, le blog sur les génériques de dessins animés
	Frame skipping happens when you convert RMVB to any other format using ffMpegX. Its absolutely normal. I get the same thing when converting the file too. Just let it finish running. It might take a while though depending on the speed of your computer and source video.
 To ascertain the correct framerate, open the file in real player, and press command-i. Under streams, the encoded framerate should be displayed. Use the same one or the closest default in ffMpegX. For instance, if the RMVB is encoded at 24fps, use NTSC film. If the framerate is entered wrongly in ffMpegX, audio might end up being out of sync.
	Thanks so much for this advice.
 I checked in real player, and the original frame rate was indeed 23fps. I then persisted in ffmpegx and let the process (and frame skipping) run, and after 8 minutes, it finished. The audio is slightly out of sync, but the video is certainly watchable.
 I greatly appreciate your help.
  Convert 30fps to 24fps skipping every 5th frame?By DragonQ in forum EditingReplies: 7Last Post: 29th Jan 2011, 04:11
  skipping frame! error?By v0llrath in forum ffmpegX general discussionReplies: 5Last Post: 30th Nov 2009, 15:43
  Frame Skipping in Media Player ClassicBy Sootmouth in forum Newbie / General discussionsReplies: 0Last Post: 7th Oct 2009, 20:00
  MEncoder skipping frame with audio conversionBy Towin in forum Video ConversionReplies: 2Last Post: 24th Mar 2008, 12:08
  dazzle video capture frame skippingBy VistaXP in forum Capturing and VCRReplies: 2Last Post: 2nd Jun 2007, 19:00
 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
				 Visit Homepage
				Visit Homepage
