Just wondered if anyone has used one of the machines , they are often combos, which can upconvert vhs and recorded that onto dvd.
Does it improve things over using standard vhs output.
PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
Do you mean a DVR (Digital Video Recorder) or a converter box that uses a USB connectior or similar?
If you are asking if they improve the quality of a VHS recording, no. Some may have filtering that cleans up some noise. Or you can use a TBC (Time Base Corrector) to stabalize the video stream. Those are usually a stand alone device or built into some VCRs.
Which recorder and video enhancer do I need to record my VHS tapes to DVD?
By cnyeco1 in forum Authoring (DVD)Replies: 6Last Post: 26th Oct 2013, 06:13 -
Record to DVD and transfer VHS to DVD
By TechNoob in forum Capturing and VCRReplies: 6Last Post: 23rd May 2011, 13:16 -
DVD Recorders (VHS to DVD Recorder then record raw footage and finalize)
By aeafisme23 in forum DVD & Blu-ray RecordersReplies: 5Last Post: 16th May 2008, 14:39 -
HELP: Looking for a GOOD DVD VHS combo - Don't need to record just play...
By UNOWEN in forum DVD & Blu-ray PlayersReplies: 3Last Post: 19th Sep 2007, 12:24 -
upconverting vhs etc
By victoriabears in forum Newbie / General discussionsReplies: 10Last Post: 11th May 2007, 03:38
