    Apr 2008
    PPT 2004 for OS X allows a slideshow to be exported as a movie (Quicktime). The .mov plays back OK in QT, but ffmpegx doesn't recognize it. Anything I can do so that it is recognized?
  2. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    When you tick the Decode with QuickTime checkbox, it will convert anyway.
    (I just tried it.)
    Apr 2008
    (I just tried it.)
    Hmmm. It didn't work for me. I get the Ding! sound, but no file appears. What could I be doing wrong. I should add that I'm converting to flv using the version of ffmpegx I downloaded today.
    If I use QTAmateur to "convert" the file to .mov and then use ffmpegx to convert this file to flv, ffmpegx works OK.
    Here's the output of the terminal window:
    Last login: Tue Apr 29 08:49:30 on ttys001
    /Applications/ffmpegX.app//Contents/Resources/pbpaste | sh
    $ /Applications/ffmpegX.app//Contents/Resources/pbpaste | sh
    Encoding started on Tue Apr 29 13:19:13 PDT 2008
    FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
    Mac OSX universal build for ffmpegX
    configuration: --enable-mp3lame --enable-gpl --disable-vhook --disable-ffplay --disable-ffserver --enable-a52 --enable-xvid --enable-faac --enable-faad --enable-amr_nb --enable-pthreads --enable-x264
    libavutil version: 49.0.0
    libavcodec version: 51.9.0
    libavformat version: 50.4.0
    built on Apr 15 2006 08:41:02, gcc: 3.3 20030304 (Apple Computer, Inc. build 1666)
    [mov,mp4,m4a,3gp,3g2,mj2 @ 0x4701fc]Could not find codec parameters (Video: rawvideo, 29556x29811)
    /Users/foo/demo1.mov: could not find codec parameters
  4. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Ah yes, I tried converting to XviD. Converting (directly) to FLV didn't work for me either.
