now an UPGRADE version means it will upgrade an EXISTING windows install, ie. upgrade from XP to Vista. you CANNOT use an "upgrade" version to do a clean install. you use your existing licence for the new OS. this is probably the worst option IMO.Originally Posted by Ethlred
Results 31 to 42 of 42
I am just a worthless liar,
I am just an imbecil -
However there is a trick that I used with 98 and XP. Rename the Windows and Program folders. It was fairly easy with 98 I only needed to use a Dos boot disc but XP is trickier. I have done it two different ways. First and most time consuming was to install XP on my second hard drive, then I could rename the folders by booting off the new installation. Now I can do it with Knoppix. Or Bart's PE should I ever get around to setting up a disk.
The rename trick is what Vista is supposed to be using for the clean install. I first used it at least 8 years ago so surely MS must have figured it out by now. There is also a trick that doesn't even require anything but the Vista upgrade disk but maybe MS has blocked it with SP1 in the newer boxes.
Just googled it. Lots of sites have the trick. Apparently it still works with SP1. -
Wel,l as I've read it previously changing the motherboard as a repair is OK, Changing it as a upgrade is against the EULA. If it was such a taboo subject why does Microsoft have instructions on their website telling what to do before changing so that the windows will run?
The thing to remember if you change the motherboard on a major brand is that the Windows disk they give you may not even install. As a part of the install it checks the bios branding and then if a Dell disc in a Dell computer it installs and doesn't need activation. One reason to go back to the maker for the motherboard. -
[quote="Ethlred"]
TooLFooL wrote:
Sometimes when you replace an engine you are required to notify the authorities as the VIN is usually stamped on the engine block...sound familiar?I am just a worthless liar,
As for multiple network cards, I had that for a while. Two wireless cars plus the motherboard's built in network interface. Wasn't a problem. I don't know the details I simply read that the network address was an automatic reactivation early on. That may have changed as XP was modified over time. I know MS said they made their rules more open. Maybe I benefited. -
Originally Posted by TooLFooL
When people say MS overcharges for their operating systems I always remember just how bloody expensive CP/M was when MS was just making BASIC for Apple and S100 bus systems and no operating systems. I think it was around $500. In the early 80's. In comparison to Linux, Vista is pretty dear but in comparison to CP/M its pretty reasonable.
Well after doing some searching I found that CP/M-86 for the IBM PC was sold for $240 each. Sounds more reasonable . I might be remembering the Apple version that had hardware as well as software. -
Example Windows 2000 Pro can not be upgraded with XP Home, You have to use a XP Pro upgrade. As MS feels that XP Home would be a downgrade from Windows 2000 Pro. -
Microsoft does offer training for resellers. You can take a simple instructional course to better understand the different levels of products and licenses. You can also take more involved training to become a Microsoft Certified Professional. You may wish to check with your employer about what is available to you. Any of the licensing courses would assist you in providing informed information to your customers and an MCP is never a bad thing to have. -
Originally Posted by jagabo
Don't remember what the IBMediocre cost when it started. About 2 grand maybe so THAT would be close to 10 to 1 for CP/M. So you have a bit of a point but there is more to it. The OEM editions of are still cheaper than the hardware. And the software takes far more man hours than it did then while the hardware far less, and man hours is the main factor in cost.
Now for the Apple ][ Plus, that was just under $1,000 in 1979 so CP/m for it was 1/2 the cost of the computer though it wasn't availible until later for the Apple][. Not counting a monitor and many used their TV. My brother and I used a green screen monitor. Oops almost forgot the floppy drives since we didn't have one to start. IIRC the first one was $200. Memory was pretty dear as well. But not enough to bring the cost of hardware close to 10 to 1. Maybe 3 to 1. -
[quote="Video Head"][quote="Ethlred"]
Frankly I am still somewhat amazed when people ask for advice from me for the first time (the second time they know about me). Why the heck ask someone who's job is to sell the item with the most profit and usually is completely ignorant of even that. Only the commissioned salesmen really care about the profit. People really need to learn about Google or at least read a bloody magazine. What ever happened to buyer beware. Yes I tell people that. I am a really weird salesman.
New CPU
By Sckinhunter in forum ComputerReplies: 9Last Post: 13th Apr 2011, 01:10 -
CPU Temp.
By HotDamn! in forum ComputerReplies: 33Last Post: 8th Mar 2010, 13:21 -
CPU
By HotDamn! in forum ComputerReplies: 7Last Post: 17th Dec 2009, 01:21 -
CPU Temperatures Going Up
By wulf109 in forum ComputerReplies: 2Last Post: 8th Mar 2009, 13:45 -
CPU-Z reading for Intel Allendale cpu
By budz in forum ComputerReplies: 11Last Post: 8th Jul 2007, 19:33
