I have an mpg video file and would like to get it into DVD format that I can play on a regular DVD player. I have both Nero 6 and Ulead Moviefactory 2se. Nero doesn't recognize mpg files and Moviefactory fails to open it as well. The Moviefactory error says that the mpg is using AC3 audio and must be converted to use a compatible format. It seems Moviefactory is compatible with MPEG audio (MPA), WAV, MP3.
I've looked through the guides and did not see anything that specifically addresses my issue. I believe I must remove the audio from the mpg and save it as a separate file, then convert it and finally, put it back into the mpg file.
I have tried a couple of programs but have been unsuccessful so far. Can anyone suggest software (preferably freeware) that I might use to accomplish this task?
Thanks very much for any help, suggestions or guidance,
Brian
You can use any of the demultiplexers in the tools section. There's about 10-20 for MPEG. Try TsMuxeR
Once you get your AC3 stream, you can encode your audio with any number of the free audio encoders in the tools section. There's about 10 that will work. Try Belight
You should be able to import elementary streams into your authoring application
An easier way would be just to use FAVC (free) for the whole thing (.mpg => DVD) -
Moviefactory is stupid, apparently. AC3 is standard for DVDs. You'll degrade the audio by multiple conversions otherwise.Originally Posted by bmoret
I'd guess an MPEG with AC3 audio is a DVD rip, so it probably is already in a compatible format.
(see https://www.videohelp.com/dvd for specs)
If it is, you can simply use an authoring app like GuiforDVDauthor to produce the VOB fileset and then burn it.
You may need to demux the MPEG to separate video and audio files first.
( https://www.videohelp.com/tools?toolsearch=demux ) -
Your version of Moviefactory is ancient. Version 6 is current, I believe. I have version 6 and I can tell you that it will accept AC3 audio as input without converting. Perhaps it's time for you to upgrade.
I can't argue with AlanHK's thoughts on Moviefactory. I don't like it, but I got it specifically to test making HD DVD format discs on burnable DVD media (both single and double layer) from TV captures and it works for that. It has many drawbacks and although it is easy to use, it's not anything I'm real enthused about. With the death of HD DVD, I will probably be very unlikely to use it much in the future. I must warn you that if your source video is not at a DVD compliant resolution, Moviefactory will re-encode the video and that is VERY BAD. It's encoder sucks. If you are too cheap to upgrade Moviefactory, then the best option for you would be to convert your audio to WAV (no quality loss, but you'll go from 5.1 channels to stereo and lose surround sound) and have Moviefactory convert that back to AC3 - so stupid. Note that Moviefactory may not (not sure) allow you to input the audio from a separate file, so you may have to find something that will mux the video and audio together. MPEGVCR has a muxer that is not too fussy and might be able to give you a TS or MPG container that Moviefactory will take as input.
How to convert WAV/MPA/MP3 audio to AC3(DD) using Besweet
By Baldrick in forum User guidesReplies: 89Last Post: 11th Aug 2012, 17:14 -
How to convert WAV/MPA/MP3 to AC3 6 channels?
By katalogas in forum AudioReplies: 8Last Post: 16th Feb 2010, 15:12 -
Convert ac3 to mpa
By pcb in forum AudioReplies: 3Last Post: 5th Jan 2010, 13:39 -
How to convert MPG with AC3 audio to FLV? --> HELP
By CineManno in forum Newbie / General discussionsReplies: 3Last Post: 29th Dec 2008, 03:56 -
trying to convert AVI to DVD. mplex error. Cannot find .mpa file?
By anarchyx34 in forum ffmpegX general discussionReplies: 8Last Post: 14th Sep 2008, 20:14
