this should be easy.. but its annoying me..
I am doing split screen videos in vegas... how do i smooth the edges of each screen??
I have done it before but was ages ago and cant remember!
Thanks for your help!![]()
You can do it using track masks with a feathered effect.
Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
where is track masks? i can get to the ordinary mask when clicking on the event/pan button..
Are you using track motion for the split screen? If so, then within the track motion window, put a check in the 2d glow box and adjust the color of the color of the glow, and also adjust the blur amount...
Regards,
George -
thanks for the replies guys... all good stuff... i will try these out later!!
Jagged Edge Of Video Picture
By kenryuakuma in forum Newbie / General discussionsReplies: 3Last Post: 18th Oct 2011, 08:24 -
Editing .264 video from mini-cam in Vegas: Vegas won't read video
By bigass in forum EditingReplies: 3Last Post: 27th Dec 2010, 12:35 -
How to remove video blur?
By Djard in forum Newbie / General discussionsReplies: 10Last Post: 27th Aug 2010, 00:38 -
youtube video is very blur!
By yunakokimama in forum Video ConversionReplies: 1Last Post: 14th Oct 2008, 16:16 -
Captured video has pixel noise on top edge of display
By cohoman in forum Capturing and VCRReplies: 0Last Post: 23rd Feb 2008, 19:32
