All I can say is I am having a hell of a time converting to h.264 with Fairuse Wizard 2.8.
I have tried other programs to create a XVID, but I wanted to try this program due to the praise, and the ability for it to put it an Xbox 360 consumable format with ease.
I tried converting straight from the disc, but when I played the h.264 in Quicktime, the video was all scrambled and the audio was fine. So, I tried converting one of my IFO files to check if it was something I did, only to find out Fairuse can't do that. So I created an ISO file. Now when I try to convert, it goes to through the whole process, and at the very last second it gives me a failure during muxing error which I thought wasn't an issue anymore.I can't get it to work no matter what I do. Please help and/or educate me.
Should I just use AutoGK as that seems to work on my brothers system.
Just trying to get my video to an Xbox 360 consumable format.
Thanks ahead of time!!!
Yep, the mp4 muxing is still a bit buggy. You could mux the video and audio file using yamb if fairuse fails.
I use anydvd together with fairuse wizard to get rid the dvd encryption.
Or try another tool like ripbot264 or automkv to make h264 from dvd. -
I use DVDFab Decrypter into an ISO.
Can yamb mux the FUD file? If so, do I just need to open that file using yamb or do I need something else?
Basically, is the .FUD compatiable?
Fairuse Wizard
By Simmons in forum Video ConversionReplies: 1Last Post: 17th Aug 2011, 19:34 -
Fairuse wizard
By pensioner in forum Newbie / General discussionsReplies: 2Last Post: 26th May 2010, 13:37 -
Fairuse Wizard
By avextraxjp in forum Newbie / General discussionsReplies: 2Last Post: 20th Feb 2010, 06:38 -
FairUse Wizard error
By dudeman316 in forum DVD RippingReplies: 3Last Post: 21st Jul 2009, 13:58 -
FairUse Wizard 2.9 muxing problem
By herbapou in forum DVD RippingReplies: 2Last Post: 17th Mar 2009, 12:21
