I have a JVC XV E100 DVD player that previously played DVDs from Australia, USA and UK. I switched unit off at mains to move to new location, now when try to play any DVD gives a Region Code Error? Anyone any ideas how to fix? Thanks
Have you tried to play the same DVDs which were working before? Did you move to another zone? I wonder if your player has built-in GPS system so it can decide in which zone and what discs you are allowed to play
Some region-freeing procedures end up by opening and closing tray. This step saves new region code into memory (flash I suppose). If you have done such procedure but did do this last step then probably it worked until it was in standby mode. When you powered it off and on later, then "all regions" code was rewritten in RAM?XORO 415, Samsung HR-757
Windows: "Where do you want to go today?"
Linux: "Where do you want to go tomorrow?"
FreeBSD: "Are you guys coming, or what?" -
From doing a web search, it seems that your player requires hardware modification to become region free and there are no codes entered by remote control to do the job. So if that is right, what that means is that in the process of moving the player, you somehow caused the hardware mod to come loose. You'll need a repair.
Half of DVD Doesn't Play
By theWallflower in forum Authoring (DVD)Replies: 19Last Post: 20th Dec 2011, 23:08 -
DVD Player doesn't play menu
By nharikrishna in forum DVD & Blu-ray PlayersReplies: 6Last Post: 21st Mar 2011, 06:48 -
Cannot play Zone 1 disc on my Sony dvp-sr100 DVD player
By lea in forum DVD & Blu-ray PlayersReplies: 12Last Post: 23rd Apr 2010, 14:24 -
DVD+R Doesn't play after halfway through
By cfresh13 in forum DVD RippingReplies: 9Last Post: 21st Mar 2008, 20:28 -
Looking for a region free /zone free DVD Recorder. Questions about the zone
By perdue27 in forum DVD & Blu-ray RecordersReplies: 11Last Post: 10th Mar 2008, 15:09
