Hi,
Really like how simple SVCD2DVD is to use, but i'm have one problem.
When i put my background picture in and preview the menu, the picture looks really bad quality,
and seems to blur the text. I'm using widescreen so made the picture 1024 x 576 and 300dpi
and another version at 72 dpi.
At first i thought maybe just the preview looks bad, but put it on disk and still looks that bad.
So am i doing something wrong ?? Any help will be most appreciated.
I believe the picture is distorted because it is too wide and is being squeezed horizontally - try a 720 x 576 image.
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
Still looks the same and also stretched, the 1024 x 576 looks like the right size and aspect ratio etc. Just looks horribbly pixelated.
Thanks alot anyway
I have a version which gives more bitrate to the menu and so eliminates the "pixelization". Email me if you would like to try it.
Thanks mate, looks better now with the newer version.
Thanks Again
Scott -
could i try this as well chrissy having same problem have sent email cheers.
Picture as Menu Background in Adobe Photoshop
By boofer in forum Authoring (DVD)Replies: 3Last Post: 16th Oct 2008, 01:41 -
convertxtodvd background menu fit.
By dymx in forum Newbie / General discussionsReplies: 2Last Post: 9th Jun 2008, 20:52 -
Video background is pixelated
By RagingSloth in forum Newbie / General discussionsReplies: 27Last Post: 23rd Apr 2008, 11:04 -
Sound on Background menu but not on DVD chapters....?
By tikigod19 in forum Authoring (DVD)Replies: 10Last Post: 3rd Aug 2007, 19:14 -
Panning Menu Background
By TerryNG in forum Authoring (DVD)Replies: 11Last Post: 14th Jun 2007, 04:01
