  1. Member joelson's Avatar
    May 2004
    Brazil
    Hi All!
    My mobile phone records video in MP4 format. I'd like to convert it to a "friendly" format, like AVI or MPEG. I'm using Mp4Cam2AVI. However, it doesn't compact very well. For example, a 30 seconds video had 7 MB!
    How can I compress it better?
    Thanks in advance!
    Best regards,
    Joelson.
  2. Member joelson's Avatar
    May 2004
    Brazil
    Nobody???
    Best regards,
    Joelson.
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Neither of those formats will give you the same quality as the same or smaller size. If your phone records in true H264 format then it is about as efficient as you can get.
    Start by opening the file in Media Info or Video Inspector to find out what resolution, format and bitrate the phone records at, then we might be able to suggest an alternative.
    Read my blog here.
  4. Member joelson's Avatar
    May 2004
    Brazil
    guns1inger: thanks for the reply!
    I've tried Video Inspector, but it doesn't seem to handle the MP4 format.
    I've obtained the information below with MediaInfo:
    General #0
    Complete name : C:\27042008(001).mp4
    Format : MPEG-4
    Format/Info : ISO 14496-1 version 2
    Format/Family : MPEG-4
    File size : 1.89 MiB
    PlayTime : 34s 933ms
    Bit rate : 455 Kbps
    StreamSize/String : 18.6 KiB
    Encoded date : UTC 2008-04-27 22:52:59
    Tagged date : UTC 2008-04-27 22:52:59
    Video #0
    Codec : MPEG-4 Visual
    Codec/Family : MPEG-4V
    Bit rate mode : CBR
    Bit rate : 379 Kbps
    Nominal bit rate : 422 Kbps
    Width : 320 pixels
    Height : 240 pixels
    Display Aspect ratio : 4/3
    Frame rate mode : VFR
    Frame rate : 9.819 fps
    Minimum frame rate : 5.000 fps
    Maximum frame rate : 15.000 fps
    Bits/(Pixel*Frame) : 0.502
    StreamSize/String : 1.58 MiB
    Audio #0
    Codec : AAC LC
    Codec/Family : AAC
    Codec/Info : AAC Low Complexity
    PlayTime : 34s 794ms
    Bit rate mode : CBR
    Bit rate : 72.0 Kbps
    Channel(s) : 1 channel
    Channel positions : C
    Sampling rate : 48.0 KHz
    Resolution : 16 bits
    StreamSize/String : 306 KiB
    Encoded date : UTC 2008-04-27 22:53:01
    Tagged date : UTC 2008-04-27 22:53:01
    Does it help?
    Thank you!
    Best regards,
    Joelson.
  5. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    It is going to be difficult to convert nicely to most other formats because it is variable framerate. It is already pretty well compressed - low resolution, low bitrate, low framerate. There isn't much to squeeze without doing damage.
    You could try using something like SUPER going to WMV and see how oyu go, but expect the quality to drop.
    Read my blog here.
  6. Member joelson's Avatar
    May 2004
    Brazil
    Interesting. I just couldn't find the download link for SUPER in the official site. And the mirror link is broken.
    Best regards,
    Joelson.
    Oct 2007
    The mirror link is working just fine.
    http://download.videohelp.com/download/SUPERsetup200830.exe
  8. Banned
    Jun 2007
    UNREACHABLE
    A URL do download "oficial" também está funcionando por aqui:
    http://www.erightsoft.org/GetFile.php?SUPERsetup.exe
    Vai ver que o servidor deles não gostou do seu endereço IP...
