  1. Just received a lovely little UA302 USB to 3.5mm Jack Audio Adapter ,bought for a spot of headphone/microphone use.
    All very plug and play ,auto configured itself correctly in sound devices(control panel),and yet although headphone playback is fine,i can't hear any microphone sound.
    Mike is not muted,and i can hear hiss,so it wants to work!
    Same on my 2 different mikes,and the control panel sound test records no voice.
    What do i need to tweak please?
    Can't record nor amplify anything,mikes are dead.
    The driver the device is using is Microsoft 5.1.2600.2180 (01.07.2001 ),could this be it ,anyone know of a newer/better alternative?
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    I would try it on another PC. If it works, then you know the problem exists on your PC.
    Why do you need an adapter? Are you saying that you have a USB microphone and you are converting it to 1/8 mini-jack? If so, why not just use it as a USB device? I'd be suspicious of the converter and whether or not Windows is properly identifying and can properly communicate with the device.
    Google is your Friend
