hi , well i have some basic networking videos tutorials in wmv format and i would like to extract
only the audio portion and convert it to mp3 so that i can listen the files on my cellphone . i have tried using goldwave but it converts only around 5 mins of the 35 mins tutorials.
below you can find the codecs used by the wmv file:
i have been doing some extensive research here and on the net but still have not found a solution.
if someone could help me that would be great.
thanks in advance[/img]
Results 1 to 16 of 16
That seems small for an 800 x 600 video that is 35 minutes long.
It is mainly text slides ?
Have you played it all the way through ?
If it is all complete, the simplest solution might be to play it the video and record and encode the audio in real-time as it plays.
Otherwise you might try SUPERRead my blog here.
how to do this ? -
Goldwave should be able to do this. Just set the input as whatever the wav playback device is. This varies from sound card to sound card (I used to have on that called it 'What U Hear').
Audacity can also do this. Just open your audio editor and have a play with the recording options.
I am still not convinced that Goldwave isn't actually recording all you haveRead my blog here.
Read my blog here.
No. You could only use audacity in this instance to record as you play back.
so what i understands by this is that i just i play the wmv file with windows media player and simultaneously i record the file with audacity. is that what u mean? -
not working .i'm getting error : cannot decompress audio streamOriginally Posted by AlanHK
Okay, all else failing, just play in in Windows Media Player and record the output. As others said, you can do this in Audacity.
See audacity-tutorial and recording & streaming.
Or you can use Audioflash. -
ok friends i finally get it right using goldwave.i had to do some trial and error with the settings until i finally get it right.i was in a hurry yesterday that 's why i was not getting the result and i just spend some time learning the software until everything is fine.
big thanks to everyone
how to demux mkv file?
By shun in forum EditingReplies: 10Last Post: 24th Mar 2014, 08:31 -
I have a .mpg file that I need to demux I want the audio..
By J Tinsby in forum Video ConversionReplies: 6Last Post: 23rd Jun 2011, 19:20 -
WMV demux?
By vato76 in forum EditingReplies: 6Last Post: 6th Apr 2011, 00:35 -
How do i convert or demux an .aac file?
By mrjust in forum Newbie / General discussionsReplies: 4Last Post: 5th Apr 2010, 00:03 -
I want to demux an .mp4 file and convert to a microsoft dv .avi file
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 4Last Post: 13th Sep 2009, 22:42
