My question is related to the "video processing->User: cropping and padding values..." option. Is there a way to set the padding values globally? As of now, I have to go to each movie clip and set their values, which is somewhat of a hassle when you have 7-10 movie clips.
Results 1 to 13 of 13
With convertxtodvd 3 you have to do each clip separately unless you have merged them into one titleset.
Thanks for the response.
I have another question, is there a way to make the audio background longer on the main menu? It seems like the length it plays is determined on how long the thumbnail motion is set before it loops, but I don't know how to change that either. -
You cannot change that. It is hardcoded based on the menu template you choose.
Thanks for the post.Originally Posted by marioval
Anyone have any issues with subtitles flickering using ConvertXToDVD 3? -
No i've never had that issue with subtitles. I also have to correct myself from above. Even if you merge multiple videos into one titleset, you still have to pad/crop each video individually.
Thanks for the info.Originally Posted by marioval
I looked at the rendered DVD on another TV Set and the subtitles flickering was not noticable, so maybe it is TV or DVD specific. -
As I don't need the menu features, I have mostly stopped using ConvertXtoDVD in favour of the far more flexible and higher quality FAVC. It will let you set the overscan borders for all titles, as will DVD Flick, both of are free. I do keep a copy of ConvertXtoDVD lying around, as it still works well with the occasional file that the others choke on, but using it is now the exception, rather than the rule.
Read my blog here.
Greetings guns1inger, yesterday, I came across a post of yours through google where provided your thoughts on subtitles and flickering. I believe you stated that flickering was something one had to deal with unless you had the timecodes of the original video or something like thatOriginally Posted by guns1inger
Back on topic, I downloaded DVD flick yesterday and here are some questions I have for you:
1) It didn't seem to work with AviSynth, I guess you do this in the "add overscan border" in advanced video properties?
2) Is there a way to automatically import the subtitles into DVD Flick when the you add the video? In most applications, if you name the subtitle the same name as the video, it imports the subtitle automatically. Also, I also notice it doesn't recognize the internal subtile in the MKV file I am using to test.
I will download FAVC and will probably have questions about that as well. -
Are you running a 32 or 64 bit operating system ? Unless you are running the 64 bit XP (and you will know, because drivers will be hard to get and buggy), use the 32 bit version.
The specific post you were referring to regarding subtitles was a special case. The OP had been using subtitles to transfer the date and time code information from a DV tape so it could be switched on or off by the user. He had been hoping to get a smooth timecode ticking over the seconds. The nature of subtitles means that this is not possible. For standard text subtitles this isn't an issue, and you should not be getting flickering.
No, DVD Flick and FAVC don't automatically recognise and load subtitles, and neither of them will find subtitles in an MKV file. I have never found this to be an issue because I have found most MKV files to be dodgy and I usually extract and repack them with just the content I am going to convert - video and audio only. I can keep any subs that I might need and load when converting.Read my blog here.
Chapters in ConvertXtoDVD. Have a question.
By KTV86 in forum Authoring (DVD)Replies: 8Last Post: 15th Oct 2009, 04:35 -
Question about ConvertXtoDVD
By ccm2 in forum Newbie / General discussionsReplies: 3Last Post: 8th Aug 2008, 03:06 -
Convertxtodvd Question
By OhSnap in forum Newbie / General discussionsReplies: 4Last Post: 1st Jun 2008, 20:59 -
Question about new ConvertXtoDVD v3.00... overscan?
By andre477 in forum Newbie / General discussionsReplies: 7Last Post: 9th Mar 2008, 13:44 -
ConvertXtoDVD question
By kostnkost in forum Video ConversionReplies: 13Last Post: 30th Dec 2007, 10:26
