i have a .mov file. which guide would i want to use to change that to a wmv or avi file
thanks for your input
Results 1 to 9 of 9
If from a camera it might work with mp4camtoavi. Or else super, winff, mpeg streamclip, quicktime pro, winavi, etc.
i have another question. where could i download the avi codec for free. the movie isn't working in windows movie maker still
The file C:\Documents and Settings\Owner.YOUR-09F6CB889E\My Documents\My Videos\DSCN3904.avi.AVI cannot be imported because the codec required to play the file is not installed on your computer. If you have already tried to download and install the codec, close and restart Windows Movie Maker, and then try to import the file again.
this is exactly what it says when i try to import the movie. i'm not great with this stuff. so maybe i'm reading it wrong -
Use MediaInfo
and/or GSpotMedia Info supplies technical and tag information about a video or audio file.
BTWEstablishes what video and audio codecs are required to play any video.
This AVI file is after transcoding from MOV?
If yes, what's used converter? -
And You choose codec in SUPER...?Originally Posted by freak93
I'm guess... install Xvid codec.
Newbie Question - H.264 MOV -> Playable HD Format ???
By Rake in forum Newbie / General discussionsReplies: 2Last Post: 6th Dec 2011, 06:31 -
PNG Codec / MOV container question regarding a setting
By low-fat-al in forum Video ConversionReplies: 3Last Post: 12th Oct 2011, 20:12 -
question about converting mov file to mp4
By cduval04 in forum Video ConversionReplies: 2Last Post: 10th Jan 2009, 20:34 -
Question about converting .mov
By spyderwings in forum Video ConversionReplies: 14Last Post: 8th Jan 2009, 05:46 -
Question about .MOV conversion
By jwfc in forum Newbie / General discussionsReplies: 1Last Post: 15th Feb 2008, 16:03
