http://i306.photobucket.com/albums/nn249/Driftking978/untitled12.jpg
i get those gray lines everytime i capture. why is that happening?
Looks like a bug in the codec. What compression format is it? Incorrectly encoded or decoded DV can create things like that.
John Miller -
well, i use arcsoft totalmedia to capture it. doesnt let me choose a compression. after i finished capturing the show, it had those lines. i encoded the mpeg-2, compressed it with xvid.
what type of capture program should i use to capture? and what codec should i use to compress? i tried virtualdub, always crashes my system when i start it. any other good ones?
Not sure if I missed it, but where are the details according to capture device in use ?
It may not be "software" related, so supply those other details, or people will be second guessing the problem. -
Capture problem grr
By Digitalexp in forum Capturing and VCRReplies: 6Last Post: 27th Mar 2012, 17:48 -
DV Capture Problem
By sailworkless in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 22nd Sep 2011, 09:14 -
capture problem
By Mario09 in forum Capturing and VCRReplies: 2Last Post: 21st Jan 2011, 06:10 -
Problem:Using Video Capture Card for capture or spy another PC.
By gmchn83 in forum Video Streaming DownloadingReplies: 1Last Post: 15th May 2009, 14:56 -
Capture problem
By jjaha in forum Capturing and VCRReplies: 0Last Post: 9th Mar 2008, 14:08
