  1. Member hardcorejason's Avatar
    Mar 2008
    I hope I posted in the right place. wasn't sure if this should go in video conversion, authoring, or audio. but if this is in the wrong place I apologize. Here's my problem, everytime I use Besweet to convert the audio of an .avi file and convert & burn to dvd with ConvertxtoDVD, the dvd movie plays just fine on my home DVD player, but on anybody else's it either has no sound or the movie plays choppy like/stop and go. But this only happens when I use Besweet as the audio converter, with FFMPEG I have 0 problems. I can't see what I could be possibly doing wrong here, I use the basic settings for AC3 and MP2. the bitrate is usually set to either 256 or 192, no higher and no lower. Freq. is always at 48000. Any help or insight would be greatly appreciated. I tried searching around for anyone who had a similar issue, but found nothing. Thanks again!
    Jason
    Sep 2007
    Europe
    If FFmpeg gives no problems then try FFmpeggui (see tools on the left).
    This should be able to convert your audio directly from the AVI.
